[postgis-tickets] r16368 - Add ST_OrientedEnvelope
Daniel Baston
dbaston at gmail.com
Fri Feb 2 09:10:07 PST 2018
Author: dbaston
Date: 2018-02-02 09:10:07 -0800 (Fri, 02 Feb 2018)
New Revision: 16368
trunk/NEWS
trunk/doc/reference_processing.xml
trunk/postgis/lwgeom_geos.c
trunk/postgis/postgis.sql.in
trunk/regress/Makefile.in
Resolves #3176
Modified: trunk/NEWS
--- trunk/NEWS 2018-02-01 02:32:33 UTC (rev 16367)
+++ trunk/NEWS 2018-02-02 17:10:07 UTC (rev 16368)
@@ -7,6 +7,7 @@
- #3896, PostGIS_Extensions_Upgrade()
- #3913, Upgrade when creating extension from unpackaged (Sandro Santilli)
- #2256, _postgis_index_extent() for extent from index (Paul Ramsey)
+ - #3176, Add ST_OrientedEnvelope (Dan Baston)
* Breaking Changes *
- #3885, version number removed from address_standardize lib file
Modified: trunk/doc/reference_processing.xml
--- trunk/doc/reference_processing.xml 2018-02-01 02:32:33 UTC (rev 16367)
+++ trunk/doc/reference_processing.xml 2018-02-02 17:10:07 UTC (rev 16368)
@@ -2170,6 +2170,57 @@
</refentry>
+ <refentry id="ST_OrientedEnvelope">
+ <refnamediv>
+ <refname>ST_OrientedEnvelope</refname>
+ <refpurpose>Returns a minimum rotated rectangle enclosing a geometry.</refpurpose>
+ </refnamediv>
+ <refsynopsisdiv>
+ <funcsynopsis>
+ <funcprototype>
+ <funcdef>geometry<function>ST_OrientedEnvelope</function></funcdef>
+ <paramdef>
+ <type>geometry</type>
+ <parameter>geom</parameter>
+ </paramdef>
+ </funcprototype>
+ </funcsynopsis>
+ </refsynopsisdiv>
+ <refsection>
+ <title>Description</title>
+ <para>
+ Returns a mimimum rotated rectangle enclosing a geometry.
+ Note that more than one minimum rotated rectangle may exist.
+ May return a Point or LineString in the case of degenerate inputs.
+ </para>
+ <para>
+ Availability - 2.5.0
+ </para>
+ </refsection>
+ <refsection>
+ <title>See Also</title>
+ <para>
+ <xref linkend="ST_Envelope" />
+ <xref linkend="ST_MinimumBoundingCircle" />
+ </para>
+ </refsection>
+ <refsection>
+ <title>Examples</title>
+ <programlisting>
+ SELECT ST_AsText(ST_OrientedEnvelope('MULTIPOINT ((0 0), (-1 -1), (3 2))'));
+ st_astext
+ POLYGON((3 2,2.88 2.16,-1.12 -0.84,-1 -1,3 2))
+ </programlisting>
+ </refsection>
+ </refentry>
<refentry id="ST_Polygonize">
<refnamediv>
<refname>ST_Polygonize</refname>
Modified: trunk/postgis/lwgeom_geos.c
--- trunk/postgis/lwgeom_geos.c 2018-02-01 02:32:33 UTC (rev 16367)
+++ trunk/postgis/lwgeom_geos.c 2018-02-02 17:10:07 UTC (rev 16368)
@@ -3627,3 +3627,46 @@
#endif
+ * ST_OrientedEnvelope
+Datum ST_OrientedEnvelope(PG_FUNCTION_ARGS);
+PG_FUNCTION_INFO_V1(ST_OrientedEnvelope);
+#if POSTGIS_GEOS_VERSION < 36
+ lwpgerror("The GEOS version this PostGIS binary "
+ "was compiled against (%d) doesn't support "
+ "'ST_OrientedEnvelope' function (3.6.0+ required)",
+ POSTGIS_GEOS_VERSION);
+ PG_RETURN_NULL();
+#else
+ GSERIALIZED* input;
+ GSERIALIZED* result;
+ GEOSGeometry* input_geos;
+ GEOSGeometry* result_geos;
+ int srid;
+ initGEOS(lwpgnotice, lwgeom_geos_error);
+ input = PG_GETARG_GSERIALIZED_P(0);
+ srid = gserialized_get_srid(input);
+ input_geos = POSTGIS2GEOS(input);
+ if (!input_geos)
+ HANDLE_GEOS_ERROR("Geometry could not be converted to GEOS");
+ result_geos = GEOSMinimumRotatedRectangle(input_geos);
+ GEOSGeom_destroy(input_geos);
+ if (!result_geos)
+ HANDLE_GEOS_ERROR("Error computing oriented envelope");
+ GEOSSetSRID(result_geos, srid);
+ result = GEOS2POSTGIS(result_geos, LW_FALSE);
+ GEOSGeom_destroy(result_geos);
+ PG_FREE_IF_COPY(input, 0);
+ PG_RETURN_POINTER(result);
+#endif
Modified: trunk/postgis/postgis.sql.in
--- trunk/postgis/postgis.sql.in 2018-02-01 02:32:33 UTC (rev 16367)
+++ trunk/postgis/postgis.sql.in 2018-02-02 17:10:07 UTC (rev 16368)
@@ -3324,6 +3324,12 @@
AS 'MODULE_PATHNAME', 'ST_MinimumBoundingCircle'
LANGUAGE 'c' IMMUTABLE STRICT _PARALLEL;
+-- Availability: 2.5.0
+CREATE OR REPLACE FUNCTION ST_OrientedEnvelope(geometry)
+ RETURNS geometry
+ AS 'MODULE_PATHNAME', 'ST_OrientedEnvelope'
+ LANGUAGE 'c' IMMUTABLE STRICT _PARALLEL;
-- Availability: 2.0.0 - requires GEOS-3.2 or higher
CREATE OR REPLACE FUNCTION ST_OffsetCurve(line geometry, distance float8, params text DEFAULT '')
RETURNS geometry
Modified: trunk/regress/Makefile.in
--- trunk/regress/Makefile.in 2018-02-01 02:32:33 UTC (rev 16367)
+++ trunk/regress/Makefile.in 2018-02-02 17:10:07 UTC (rev 16368)
@@ -229,7 +229,8 @@
# GEOS-3.6 adds:
# ST_MinimumClearance
TESTS += \
- minimum_clearance
+ minimum_clearance \
+ oriented_envelope
endif
ifeq ($(HAVE_JSON),yes)
