[postgis-tickets] r16372 - Fix versions to be compatible with what SFCGAL was compiled with.
Regina Obe lr at pcorp.us
Fri Feb 2 08:46:42 PST 2018
Author: robe
Date: 2018-02-02 20:46:42 -0800 (Fri, 02 Feb 2018)
New Revision: 16372
   trunk/ci/winnie/build_postgis.sh
   trunk/ci/winnie/package_postgis.sh
   trunk/ci/winnie/regress_postgis.sh
Modified: trunk/ci/winnie/build_postgis.sh
--- trunk/ci/winnie/build_postgis.sh	2018-02-02 22:23:31 UTC (rev 16371)
+++ trunk/ci/winnie/build_postgis.sh	2018-02-03 04:46:42 UTC (rev 16372)
@@ -13,18 +13,22 @@
 #POSTGIS_MICRO_VERSION=0SVN
 #export GCC_TYPE=gcc48  #for pre-4.8.0 compiles this is blank
 #export JSON_VER=0.9
-#export SFCGAL_VER=1.0.4
+#export SFCGAL_VER=1.3
 #export PROJ_VER=4.8.0
+#export GEOS_VER=3.7.0dev
+#export GDAL_VER=2.2.3
+#export PROJ_VER=4.9.3
-export GDAL_VER=2.2.2
+export GDAL_VER=2.2.3
-export SFCGAL_VER=1.3
+export SFCGAL_VER=1.3.2
 export PCRE_VER=8.33
 export PROTOBUF_VER=3.2.0
 export PROTOBUFC_VER=1.2.1
+export CGAL_VER=4.11
-export PROTOBUF_VER=3.2.0
 export LIBXML_VER=2.7.8
 if [[ "${GCC_TYPE}" == *gcc48* ]] ; then
@@ -104,8 +108,6 @@
 fi
 if [ -n "$SFCGAL_VER" ]; then
-	##hard code versions of cgal etc. for now
-	export CGAL_VER=4.2
 	BOOST_VER=1.53.0
 	#BOOST_VER_WU=1_49_0
 	export BOOST_VER_WU=1_53_0
Modified: trunk/ci/winnie/package_postgis.sh
--- trunk/ci/winnie/package_postgis.sh	2018-02-02 22:23:31 UTC (rev 16371)
+++ trunk/ci/winnie/package_postgis.sh	2018-02-03 04:46:42 UTC (rev 16372)
@@ -13,12 +13,13 @@
 #export GCC_TYPE=
 	export PROJECTS=/projects
@@ -144,7 +145,6 @@
 	## only copy cgal and sfcgal stuff if sfcgal is packaged
-	export CGAL_VER=4.6.1
 	export BOOST_VER=1.59.0
 	export BOOST_VER_WU=1_59_0
 	export GMP_VER=5.1.2
Modified: trunk/ci/winnie/regress_postgis.sh
--- trunk/ci/winnie/regress_postgis.sh	2018-02-02 22:23:31 UTC (rev 16371)
+++ trunk/ci/winnie/regress_postgis.sh	2018-02-03 04:46:42 UTC (rev 16372)
@@ -9,20 +9,21 @@
 #export POSTGIS_MAJOR_VERSION=2
 #export POSTGIS_MINOR_VERSION=2
 #export POSTGIS_MICRO_VERSION=0dev
+#export GDAL_VER=2.2.2
+#export PCRE_VER=8.33
+#export PROTOBUF_VER=3.2.0
+#export PROTOBUFC_VER=1.2.1
+#export CGAL_VER=4.11
 export MINGPROJECTS=/projects
 export PATHOLD=$PATH
-export GEOS_VER=3.7.0dev
-export PROJ_VER=4.9.3
-export PCRE_VER=8.33
-export PROTOBUFC_VER=1.2.1
 if [ "$OS_BUILD" == "64" ] ; then
 	export MINGHOST=x86_64-w64-mingw32
 else
@@ -93,7 +94,7 @@
+	#export CGAL_VER=4.11
 	BOOST_VER=1.53.0
