[postgis-tickets] r16371 - Apply node sorting before descent to CIRC_NODE trees for
Paul Ramsey
pramsey at cleverelephant.ca
Fri Feb 2 02:23:31 PST 2018
Author: pramsey
Date: 2018-02-02 14:23:31 -0800 (Fri, 02 Feb 2018)
New Revision: 16371
trunk/liblwgeom/lwgeodetic_tree.c
trunk/liblwgeom/lwgeodetic_tree.h
faster calculation of geography distances.
Closes #4010
Modified: trunk/liblwgeom/lwgeodetic_tree.c
--- trunk/liblwgeom/lwgeodetic_tree.c 2018-02-02 21:42:12 UTC (rev 16370)
+++ trunk/liblwgeom/lwgeodetic_tree.c 2018-02-02 22:23:31 UTC (rev 16371)
@@ -601,6 +601,51 @@
+* Internal node sorting routine to make distance calculations faster?
+struct sort_node {
+ CIRC_NODE *node;
+ double d;
+static int
+circ_nodes_sort_cmp(const void *a, const void *b)
+ struct sort_node *node_a = (struct sort_node *)(a);
+ struct sort_node *node_b = (struct sort_node *)(b);
+ if (node_a->d < node_b->d) return -1;
+ else if (node_a->d > node_b->d) return 1;
+ else return 0;
+static void
+circ_internal_nodes_sort(CIRC_NODE **nodes, uint32_t num_nodes, const CIRC_NODE *target_node)
+ int i;
+ struct sort_node sort_nodes[CIRC_NODE_SIZE];
+ /* Copy incoming nodes into sorting array and calculate */
+ /* distance to the target node */
+ for (i = 0; i < num_nodes; i++)
+ sort_nodes[i].node = nodes[i];
+ sort_nodes[i].d = sphere_distance(&(nodes[i]->center), &(target_node->center));
+ /* Sort the nodes and copy the result back into the input array */
+ qsort(sort_nodes, num_nodes, sizeof(struct sort_node), circ_nodes_sort_cmp);
+ nodes[i] = sort_nodes[i].node;
+ return;
static double
circ_tree_distance_tree_internal(const CIRC_NODE* n1, const CIRC_NODE* n2, double threshold, double* min_dist, double* max_dist, GEOGRAPHIC_POINT* closest1, GEOGRAPHIC_POINT* closest2)
@@ -746,6 +791,7 @@
/* tests above. */
if ( n1->geom_type && lwtype_is_collection(n1->geom_type) )
+ circ_internal_nodes_sort(n1->nodes, n1->num_nodes, n2);
for ( i = 0; i < n1->num_nodes; i++ )
d = circ_tree_distance_tree_internal(n1->nodes[i], n2, threshold, min_dist, max_dist, closest1, closest2);
@@ -754,6 +800,7 @@
else if ( n2->geom_type && lwtype_is_collection(n2->geom_type) )
+ circ_internal_nodes_sort(n2->nodes, n2->num_nodes, n1);
for ( i = 0; i < n2->num_nodes; i++ )
d = circ_tree_distance_tree_internal(n1, n2->nodes[i], threshold, min_dist, max_dist, closest1, closest2);
@@ -762,6 +809,7 @@
else if ( ! circ_node_is_leaf(n1) )
@@ -770,6 +818,7 @@
else if ( ! circ_node_is_leaf(n2) )
Modified: trunk/liblwgeom/lwgeodetic_tree.h
--- trunk/liblwgeom/lwgeodetic_tree.h 2018-02-02 21:42:12 UTC (rev 16370)
+++ trunk/liblwgeom/lwgeodetic_tree.h 2018-02-02 22:23:31 UTC (rev 16371)
@@ -41,6 +41,7 @@
struct circ_node** nodes;
int edge_num;
uint32_t geom_type;
+ double d;
POINT2D pt_outside;
POINT2D* p1;
POINT2D* p2;
