r16375 - Fix build tests around geometric median (Raúl Marín Rodríguez)
Paul Ramsey
pramsey at cleverelephant.ca
Thu Feb 8 12:59:21 PST 2018
Author: pramsey
Date: 2018-02-08 12:59:20 -0800 (Thu, 08 Feb 2018)
New Revision: 16375
trunk/liblwgeom/cunit/cu_algorithm.c
trunk/liblwgeom/liblwgeom_internal.h
trunk/liblwgeom/lwgeom_median.c
Closes https://github.com/postgis/postgis/pull/205
Closes #4012
Modified: trunk/liblwgeom/cunit/cu_algorithm.c
--- trunk/liblwgeom/cunit/cu_algorithm.c 2018-02-08 19:11:45 UTC (rev 16374)
+++ trunk/liblwgeom/cunit/cu_algorithm.c 2018-02-08 20:59:20 UTC (rev 16375)
@@ -1115,6 +1115,19 @@
do_median_dims_check("MULTIPOINT ZM ((1 3 4 5), (4 7 8 6), (2 9 1 7), (0 4 4 8), (2 2 3 9))", 3);
+static double
+test_weighted_distance(const POINT4D* curr, const POINT4D* points, uint32_t npoints)
+ double distance = 0.0;
+ uint32_t i;
+ for (i = 0; i < npoints; i++)
+ distance += distance3d_pt_pt((POINT3D*)curr, (POINT3D*)&points[i]) * points[i].m;
+ return distance;
static void do_median_test(char* input, char* expected, int fail_if_not_converged, int iter_count)
cu_error_msg_reset();
@@ -1142,15 +1155,43 @@
passed = LW_TRUE;
passed = passed && lwgeom_is_empty((LWGEOM*) expected_result) == lwgeom_is_empty((LWGEOM*) result);
passed = passed && (lwgeom_has_z((LWGEOM*) expected_result) == lwgeom_has_z((LWGEOM*) result));
- if (!lwgeom_is_empty((LWGEOM*) result))
+ if (passed && !lwgeom_is_empty((LWGEOM*) result))
- passed = passed && fabs(actual_pt.x - expected_pt.x) < tolerance;
- passed = passed && fabs(actual_pt.y - expected_pt.y) < tolerance;
- passed = passed && (!lwgeom_has_z((LWGEOM*) expected_result) || fabs(actual_pt.z - expected_pt.z) < tolerance);
- passed = passed && (!lwgeom_has_m((LWGEOM*) expected_result) || fabs(actual_pt.m - expected_pt.m) < tolerance);
+ if (g->type == POINTTYPE)
+ passed &= fabs(actual_pt.x - expected_pt.x) < tolerance;
+ passed &= fabs(actual_pt.y - expected_pt.y) < tolerance;
+ passed &= (!lwgeom_has_z((LWGEOM*) expected_result) || fabs(actual_pt.z - expected_pt.z) < tolerance);
+ passed &= (!lwgeom_has_m((LWGEOM*) expected_result) || fabs(actual_pt.m - expected_pt.m) < tolerance);
+ else
+ /* Check that the difference between the obtained geometric
+ median and the expected point is within tolerance */
+ uint32_t npoints = 1;
+ int input_empty = LW_TRUE;
+ POINT4D* points = lwmpoint_extract_points_4d(lwgeom_as_lwmpoint(g), &npoints, &input_empty);
+ double distance_expected = test_weighted_distance(&expected_pt, points, npoints);
+ double distance_result = test_weighted_distance(&actual_pt, points, npoints);
+ passed = distance_result <= (1.0 + tolerance) * distance_expected;
+ if (!passed)
+ printf("Diff: Got %.10f Expected %.10f\n", distance_result, distance_expected);
+ lwfree(points);
if (!passed)
- printf("median_test input %s (parsed %s) expected %s got %s\n", input, lwgeom_to_ewkt(g), lwgeom_to_ewkt((LWGEOM*) expected_result), lwgeom_to_ewkt((LWGEOM*) result));
+ printf("median_test input %s (parsed %s) expected %s got %s\n",
+ input, lwgeom_to_ewkt(g),
+ lwgeom_to_ewkt((LWGEOM*) expected_result),
+ lwgeom_to_ewkt((LWGEOM*) result));
else if (result == NULL && expected == NULL) /* got nothing, expecting nothing */
@@ -1231,18 +1272,46 @@
do_median_test("POLYGON((1 0,0 1,1 2,2 1,1 0))", NULL, LW_TRUE, 1000);
do_median_test("POLYGON((1 0,0 1,1 2,2 1,1 0))", NULL, LW_FALSE, 1000);
- /* Intermediate point included in the set */
+ /* Median point is included */
do_median_test("MULTIPOINT ZM ("
- "(0 0 20000 0.5),"
- "(0 0 59000 0.5),"
- "(0 48000 -20000 1.3),"
- "(0 -48000 -20000 1.3),"
- "(0 -3000 -3472.22222222222262644208967685699462890625 1),"
- "(0 3000 3472.22222222222262644208967685699462890625 1),"
- "(0 0 -1644.736842105263121993630193173885345458984375 1),"
- "(0 0 1644.736842105263121993630193173885345458984375 1)"
- "POINT (0 0 0)", LW_TRUE, 296);
+ "(1480 0 200 100),"
+ "(620 0 200 100),"
+ "(1000 0 -200 100),"
+ "(1000 0 -590 100),"
+ "(1025 0 65 100),"
+ "(1025 0 -65 100)"
+ "POINT (1025 0 -65)", LW_TRUE, 10000);
+#if 0
+ /* Leads to invalid result (0 0 0) with 80bit (fmulp + faddp) precision. ok with 64 bit float ops */
+ do_median_test("MULTIPOINT ZM ("
+ "(0 0 20000 0.5),"
+ "(0 0 59000 0.5),"
+ "(0 -3000 -3472.22222222222262644208967685699462890625 1),"
+ "(0 3000 3472.22222222222262644208967685699462890625 1),"
+ "(0 0 -1644.736842105263121993630193173885345458984375 1),"
+ "(0 0 1644.736842105263121993630193173885345458984375 1),"
+ "(0 48000 -20000 1.3),"
+ "(0 -48000 -20000 1.3)"
+ "POINT (0 0 0)", LW_TRUE, 10000);
+#endif
+#if 0
+ /* Leads to invalid result (0 0 0) with 64bit (vfmadd231sd) precision. Ok with 80 bit float ops */
+ "(0 -0.00000000000028047739569477638384522295466033823196 -1644.736842105263121993630193173885345458984375 1),"
+ "(0 0.00000000000028047739569477638384522295466033823196 1644.736842105263121993630193173885345458984375 1),"
+#endif
static void test_point_density(void)
Modified: trunk/liblwgeom/liblwgeom_internal.h
--- trunk/liblwgeom/liblwgeom_internal.h 2018-02-08 19:11:45 UTC (rev 16374)
+++ trunk/liblwgeom/liblwgeom_internal.h 2018-02-08 20:59:20 UTC (rev 16375)
@@ -500,5 +500,6 @@
int ptarray_npoints_in_rect(const POINTARRAY *pa, const GBOX *gbox);
int gbox_contains_point2d(const GBOX *g, const POINT2D *p);
int lwpoly_contains_point(const LWPOLY *poly, const POINT2D *pt);
+POINT4D* lwmpoint_extract_points_4d(const LWMPOINT* g, uint32_t* npoints, int* input_empty);
#endif /* _LIBLWGEOM_INTERNAL_H */
Modified: trunk/liblwgeom/lwgeom_median.c
--- trunk/liblwgeom/lwgeom_median.c 2018-02-08 19:11:45 UTC (rev 16374)
+++ trunk/liblwgeom/lwgeom_median.c 2018-02-08 20:59:20 UTC (rev 16375)
@@ -29,48 +29,61 @@
#include "liblwgeom_internal.h"
#include "lwgeom_log.h"
-static void
+static double
calc_weighted_distances_3d(const POINT3D* curr, const POINT4D* points, uint32_t npoints, double* distances)
uint32_t i;
+ double weight = 0.0;
- distances[i] = distance3d_pt_pt(curr, (POINT3D*)&points[i]) / points[i].m;
+ double dist = distance3d_pt_pt(curr, (POINT3D*)&points[i]);
+ distances[i] = dist / points[i].m;
+ weight += dist * points[i].m;
+ return weight;
-static double
-iterate_4d(POINT3D* curr, const POINT4D* points, uint32_t npoints, double* distances)
+static uint32_t
+iterate_4d(POINT3D* curr, const POINT4D* points, const uint32_t npoints, const uint32_t max_iter, const double tol)
- uint32_t i;
- POINT3D next = { 0, 0, 0 };
- double delta = 0;
- double denom = 0;
- char hit = LW_FALSE;
+ uint32_t i, iter;
+ double delta;
+ double sum_curr = 0, sum_next = 0;
+ int hit = LW_FALSE;
+ double *distances = lwalloc(npoints * sizeof(double));
- calc_weighted_distances_3d(curr, points, npoints, distances);
+ sum_curr = calc_weighted_distances_3d(curr, points, npoints, distances);
- for (i = 0; i < npoints; i++)
+ for (iter = 0; iter < max_iter; iter++)
- /* we need to use lower epsilon than in FP_IS_ZERO in the loop for calculation to converge */
- if (distances[i] > DBL_EPSILON)
+ POINT3D next = { 0, 0, 0 };
+ double denom = 0;
+ /** Calculate denom to get the next point */
- next.x += points[i].x / distances[i];
- next.y += points[i].y / distances[i];
- next.z += points[i].z / distances[i];
- denom += 1.0 / distances[i];
+ /* we need to use lower epsilon than in FP_IS_ZERO in the loop for calculation to converge */
+ if (distances[i] > DBL_EPSILON)
+ next.x += points[i].x / distances[i];
+ next.y += points[i].y / distances[i];
+ next.z += points[i].z / distances[i];
+ denom += 1.0 / distances[i];
+ else
+ hit = LW_TRUE;
- else
+ if (denom < DBL_EPSILON)
- hit = LW_TRUE;
+ /* No movement - Final point */
+ break;
- /* negative weight shouldn't get here */
- assert(denom >= 0);
- /* denom is zero in case of multipoint of single point when we've converged perfectly */
- if (denom > DBL_EPSILON)
+ /* Calculate the new point */
next.x /= denom;
next.y /= denom;
next.z /= denom;
@@ -91,10 +104,10 @@
if (hit)
- double dx = 0;
- double dy = 0;
- double dz = 0;
+ double dx = 0, dy = 0, dz = 0;
double d_sqr;
+ hit = LW_FALSE;
@@ -106,7 +119,6 @@
d_sqr = sqrt(dx*dx + dy*dy + dz*dz);
- /* Avoid division by zero if the intermediate point is the median */
if (d_sqr > DBL_EPSILON)
double r_inv = FP_MAX(0, 1.0 / d_sqr);
@@ -116,14 +128,24 @@
- delta = distance3d_pt_pt(curr, &next);
- curr->x = next.x;
- curr->y = next.y;
- curr->z = next.z;
+ /* Check movement with next point */
+ sum_next = calc_weighted_distances_3d(&next, points, npoints, distances);
+ delta = sum_curr - sum_next;
+ if (delta < tol)
+ break;
+ else
+ curr->x = next.x;
+ curr->y = next.y;
+ curr->z = next.z;
+ sum_curr = sum_next;
- return delta;
+ lwfree(distances);
+ return iter;
static POINT3D
@@ -146,7 +168,7 @@
return guess;
-static POINT4D*
+POINT4D*
uint32_t i;
@@ -212,9 +234,7 @@
uint32_t npoints = 0; /* we need to count this ourselves so we can exclude empties and weightless points */
uint32_t i;
- double delta = DBL_MAX;
POINT3D median;
- double* distances = NULL;
POINT4D* points = lwmpoint_extract_points_4d(g, &npoints, &input_empty);
/* input validation failed, error reported already */
@@ -236,17 +256,11 @@
median = init_guess(points, npoints);
- distances = lwalloc(npoints * sizeof(double));
+ i = iterate_4d(&median, points, npoints, max_iter, tol);
- for (i = 0; i < max_iter && delta > tol; i++)
- delta = iterate_4d(&median, points, npoints, distances);
- lwfree(distances);
lwfree(points);
- if (fail_if_not_converged && delta > tol)
+ if (fail_if_not_converged && i >= max_iter)
lwerror("Median failed to converge within %g after %d iterations.", tol, max_iter);
return NULL;
