[postgis-tickets] [PostGIS] #4016: tickets test fails with proj 5.0.0-rc2
trac at osgeo.org
Fri Feb 9 08:43:30 PST 2018
Reporter: Bas Couwenberg | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.4.4
Component: postgis | Version: 2.4.x
Keywords: |
postgis 2.4.3 failed to build with proj 5.0.0-rc2 due to the tickets test
failing:
*** /tmp/pg_virtualenv.38D232/log/postgresql-10-regress.log (last 100
lines) ***
ST_AsText(g::geometry),
ST_OrderingEquals(g::geometry,
St_GeomFromText(ST_AsText(g::geometry))) FROM ( SELECT
'CURVEPOLYGON (COMPOUNDCURVE(CIRCULARSTRING(0 0,1 1,1 0),(1 2,0
1)))'
::text as g ) as foo;
2018-02-09 16:38:58.449 UTC [16809] pbuilder at postgis_reg ERROR: geometry
requires more points
2018-02-09 16:38:58.449 UTC [16809] pbuilder at postgis_reg HINT:
"CURVEPOLYGON (COMPOUNDCURVE EMPTY)" <-- parse error at position 34 within
geometry
2018-02-09 16:38:58.449 UTC [16809] pbuilder at postgis_reg STATEMENT:
SELECT g,
'CURVEPOLYGON (COMPOUNDCURVE EMPTY)'
contains non-closed rings
"...RCULARSTRING(0 0,1 1,1 0),(1 0,0 1)))" <-- parse error at position 67
within geometry
SELECT g,
'CURVEPOLYGON (COMPOUNDCURVE(CIRCULARSTRING(0 0,1 1,1 0),(1 0,0
1)))'
2018-02-09 16:38:58.454 UTC [16809] pbuilder at postgis_reg ERROR: geometry
2018-02-09 16:38:58.454 UTC [16809] pbuilder at postgis_reg HINT: "TRIANGLE
((1 2 3,4 5 6,7 8 9,1 2 0))" <-- parse error at position 37 within
geometry
2018-02-09 16:38:58.454 UTC [16809] pbuilder at postgis_reg STATEMENT:
SELECT g,
'TRIANGLE ((1 2 3,4 5 6,7 8 9,1 2 0))'
2018-02-09 16:38:58.455 UTC [16809] pbuilder at postgis_reg ERROR: geometry
2018-02-09 16:38:58.455 UTC [16809] pbuilder at postgis_reg HINT: "...0 0 0
1, 0 1 0 2, 1 1 0 3, 0 1 0 1)) " <-- parse error at position 88 within
geometry
2018-02-09 16:38:58.455 UTC [16809] pbuilder at postgis_reg STATEMENT:
SELECT g,
'TIN ZM ( ((0 0 0 0, 0 0 1 0, 0 1 0 4, 0 0 0 0)), ((0 0 0 1, 0 1 0
2, 1 1 0 3, 0 1 0 1)) )'
2018-02-09 16:38:58.644 UTC [16813] pbuilder at postgis_reg WARNING:
ST_Force_2d signature was deprecated in 2.1.0. Please use ST_Force2D
2018-02-09 16:38:58.644 UTC [16813] pbuilder at postgis_reg CONTEXT:
PL/pgSQL function _postgis_deprecate(text,text,text) line 14 at RAISE
SQL function "st_force_2d" during startup
2018-02-09 16:38:58.645 UTC [16813] pbuilder at postgis_reg WARNING:
2018-02-09 16:38:58.645 UTC [16813] pbuilder at postgis_reg CONTEXT:
2018-02-09 16:38:58.650 UTC [16813] pbuilder at postgis_reg WARNING:
2018-02-09 16:38:58.650 UTC [16813] pbuilder at postgis_reg CONTEXT:
ST_Force_Collection signature was deprecated in 2.1.0. Please use
ST_ForceCollection
SQL function "st_force_collection" during startup
2018-02-09 16:38:58.654 UTC [16813] pbuilder at postgis_reg WARNING:
2018-02-09 16:38:58.654 UTC [16813] pbuilder at postgis_reg CONTEXT:
ST_ForceCollection
2018-02-09 16:39:18.262 UTC [16933] pbuilder at postgis_reg ERROR:
ST_OffsetCurve only works with LineStrings
2018-02-09 16:39:18.262 UTC [16933] pbuilder at postgis_reg STATEMENT:
SELECT 't0', ST_OffsetCurve('POINT(0 0)', 10);
2018-02-09 16:39:18.346 UTC [16945] pbuilder at postgis_reg ERROR: Operation
on mixed SRID geometries
2018-02-09 16:39:18.346 UTC [16945] pbuilder at postgis_reg STATEMENT:
select 't1', st_asewkt(st_sharedpaths(
'SRID=10;LINESTRING(0 0, 10 0)', 'SRID=5;LINESTRING(0 0, 100 0)'
2018-02-09 16:39:18.348 UTC [16945] pbuilder at postgis_reg ERROR:
GEOSSharedPaths: IllegalArgumentException: Geometry is not lineal
2018-02-09 16:39:18.348 UTC [16945] pbuilder at postgis_reg STATEMENT:
select 't6', st_sharedpaths(
'0101000020E6100000F771D98DE33826C00000000000004440'::geometry,
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geometry
2018-02-09 16:39:18.367 UTC [16949] pbuilder at postgis_reg ERROR: Operation
2018-02-09 16:39:18.367 UTC [16949] pbuilder at postgis_reg STATEMENT:
select 't1', st_asewkt(st_snap(
0)', 0
2018-02-09 16:39:18.802 UTC [16965] pbuilder at postgis_reg ERROR:
GEOSRelate: Invalid boundary node rule 5
2018-02-09 16:39:18.802 UTC [16965] pbuilder at postgis_reg STATEMENT:
SELECT st_relate('POINT(0 0)', 'POINT(1 0)', 5);
2018-02-09 16:39:18.856 UTC [16973] pbuilder at postgis_reg ERROR:
lwgeom_subdivide: cannot subdivide to fewer than 8 vertices per output
2018-02-09 16:39:18.856 UTC [16973] pbuilder at postgis_reg STATEMENT:
SELECT '#3135', st_astext(ST_SubDivide(ST_GeomFromText('POLYGON((1 2,1 2,1
2,1 2))'), 2));
2018-02-09 16:39:18.993 UTC [16981] pbuilder at postgis_reg ERROR: Tolerance
must be a positive number.
2018-02-09 16:39:18.993 UTC [16981] pbuilder at postgis_reg CONTEXT: SQL
function "st_voronoipolygons" statement 1
2018-02-09 16:39:18.993 UTC [16981] pbuilder at postgis_reg STATEMENT:
SELECT 3, ST_VoronoiPolygons('MULTIPOINT (0 0, 1 1, 2 2)', NULL);
SELECT 5, ST_VoronoiPolygons('MULTIPOINT (0 0, 1 1, 2 2)', -2);
2018-02-09 16:39:19.036 UTC [16989] pbuilder at postgis_reg ERROR: Unable to
find 'coordinates' in GeoJSON string
2018-02-09 16:39:19.036 UTC [16989] pbuilder at postgis_reg STATEMENT:
select '#1434.1',ST_GeomFromGeoJSON('{ "type": "Point", "crashme": [100.0,
0.0] }');
2018-02-09 16:39:19.037 UTC [16989] pbuilder at postgis_reg ERROR:
unexpected character (at offset 0)
2018-02-09 16:39:19.037 UTC [16989] pbuilder at postgis_reg STATEMENT:
select '#1434.2',ST_GeomFromGeoJSON('crashme');
unexpected end of data (at offset 0)
select '#1434.3',ST_GeomFromGeoJSON('');
2018-02-09 16:39:19.037 UTC [16989] pbuilder at postgis_reg ERROR: invalid
GeoJSON representation
select '#1434.4',ST_GeomFromGeoJSON('{}');
2018-02-09 16:39:19.037 UTC [16989] pbuilder at postgis_reg ERROR: Too few
ordinates in GeoJSON
select '#1434.5',ST_GeomFromGeoJSON('{"type":"Point","coordinates":[]}');
select
'#1434.6',ST_GeomFromGeoJSON('{"type":"MultiPoint","coordinates":[[]]}');
2018-02-09 16:39:19.037 UTC [16989] pbuilder at postgis_reg ERROR: Unable to
select '#1434.7',ST_GeomFromGeoJSON('{"type":"MultiPoint"}');
select '#1434.8',ST_GeomFromGeoJSON('{"type":"Point"}');
2018-02-09 16:39:19.038 UTC [16989] pbuilder at postgis_reg ERROR: The
'coordinates' in GeoJSON ring are not an array
2018-02-09 16:39:19.038 UTC [16989] pbuilder at postgis_reg STATEMENT:
SELECT '#2697',
ST_GeomFromGeoJSON('{"type":"Polygon","coordinates":[1]}');
SELECT '#2697',
ST_GeomFromGeoJSON('{"type":"Polygon","coordinates":[1,1]}');
2018-02-09 16:39:20.076 UTC [17005] pbuilder at postgis_reg ERROR:
pgis_asmvt_transfn: parameter row cannot be other than a rowtype
2018-02-09 16:39:20.076 UTC [17005] pbuilder at postgis_reg STATEMENT:
SELECT encode(ST_AsMVT(1, 'test', 4096, 'geom'), 'base64');
Dropping cluster 10/regress ...
### /tmp/pgis_reg/test_91_diff ###
--- tickets_expected 2018-01-16 05:31:17.000000000 +0000
+++ /tmp/pgis_reg/test_91_out 2018-02-09 16:38:53.269350614 +0000
@@ -198,7 +198,7 @@
#1578|f|f
#1580.1|Point[S]
ERROR: transform: couldn't project point (180 90 0): tolerance condition
error (-20)
-#1580.3|Point[S]
+ERROR: transform: couldn't project point (0 0 0): tolerance condition
error (-20)
#1596.1|public.road_pg.roads_geom SRID:3395 TYPE:POINT DIMS:2
ERROR: invalid SRID: 330000 not found in spatial_ref_sys
#1596.3|3395
@@ -207,7 +207,7 @@
NOTICE: SRID value -1 converted to the officially unknown SRID value 0
#1596.6|public.road_pg.roads_geom SRID changed to 0
#1596.7|0
-#1596|Point[GS]
+ERROR: transform: couldn't project point (-176 -22 0): tolerance
condition error (-20)
#1695|MULTIPOLYGON EMPTY
#1697.1|0
#1697.2|0
### end of log dumps ###
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4016>
