[postgis-tickets] [PostGIS] #4016: tickets test fails with proj 5.0.0-rc2
trac at osgeo.org
Fri Feb 16 08:08:55 PST 2018
Reporter: Bas Couwenberg | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.4.4
Component: postgis | Version: 2.4.x
Resolution: | Keywords:
Comment (by Algunenano):
This is somewhat related to #1580 which is the ticket the test was created
for.
I've solved it locally by resetting `pj_errno` to 0 after an error but I
wonder if this behaviour change in proj is intended.
Here is the PR: https://github.com/postgis/postgis/pull/210. It should
work with both PROJ 5 (tested with its current HEAD) and 4.9.3 (GH travis
build).
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4016#comment:3>
