[postgis-tickets] [PostGIS] #4016: tickets test fails with proj 5.0.0-rc2
trac at osgeo.org
Fri Feb 16 08:37:20 PST 2018
Reporter: Bas Couwenberg | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.4.4
Component: postgis | Version: 2.4.x
Resolution: | Keywords:
Comment (by Bas Couwenberg):
Replying to [comment:3 Algunenano]:
> I've solved it locally by resetting `pj_errno` to 0 after an error but I
wonder if this behaviour change in proj is intended.
The proj developers should be able to answer that, please post your
question on the list:
http://lists.maptools.org/pipermail/proj/2018-February/007990.html
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4016#comment:4>
