[postgis-tickets] r16382 - pj_transform: Reset pj_errno after any error
Darafei komzpa at gmail.com
Sat Feb 17 12:42:21 PST 2018
Author: komzpa
Date: 2018-02-17 00:42:21 -0800 (Sat, 17 Feb 2018)
New Revision: 16382
   trunk/liblwgeom/lwgeom_transform.c
Patch by Raúl Marín Rodríguez
Closes https://github.com/postgis/postgis/pull/210
References #4016
Modified: trunk/liblwgeom/lwgeom_transform.c
--- trunk/liblwgeom/lwgeom_transform.c	2018-02-17 08:37:54 UTC (rev 16381)
+++ trunk/liblwgeom/lwgeom_transform.c	2018-02-17 08:42:21 UTC (rev 16382)
@@ -130,7 +130,7 @@
 int
 point4d_transform(POINT4D *pt, projPJ srcpj, projPJ dstpj)
-	int* pj_errno_ref;
 	POINT4D orig_pt;
 	/* Make a copy of the input point so we can report the original should an error occur */
@@ -142,25 +142,25 @@
 	LWDEBUGF(4, "transforming POINT(%f %f) from '%s' to '%s'", orig_pt.x, orig_pt.y, pj_get_def(srcpj,0), pj_get_def(dstpj,0));
-	/* Perform the transform */
-	pj_transform(srcpj, dstpj, 1, 0, &(pt->x), &(pt->y), &(pt->z));
+	if (pj_transform(srcpj, dstpj, 1, 0, &(pt->x), &(pt->y), &(pt->z)) != 0)
+		int* pj_errno_ref = pj_get_errno_ref();
+		int pj_errno_val = *pj_errno_ref;
-	/* For NAD grid-shift errors, display an error message with an additional hint */
-	pj_errno_ref = pj_get_errno_ref();
+		/* Force a reset of pj_errno to avoid future errors */
+		*pj_errno_ref = 0;
-	if (*pj_errno_ref != 0)
-		if (*pj_errno_ref == -38)
+		if (pj_errno_val == -38)
 			lwnotice("PostGIS was unable to transform the point because either no grid shift files were found, or the point does not lie within the range for which the grid shift is defined. Refer to the ST_Transform() section of the PostGIS manual for details on how to configure PostGIS to alter this behaviour.");
 			lwerror("transform: couldn't project point (%g %g %g): %s (%d)",
-			        orig_pt.x, orig_pt.y, orig_pt.z, pj_strerrno(*pj_errno_ref), *pj_errno_ref);
+			        orig_pt.x, orig_pt.y, orig_pt.z, pj_strerrno(pj_errno_val), pj_errno_val);
 			return 0;
 		else
 			return 0;
