[postgis-tickets] r16383 - Add support to unstroke GEOMETRYCOLLECTION
Darafei komzpa at gmail.com
Sat Feb 17 12:46:21 PST 2018
Author: komzpa
Date: 2018-02-17 00:46:20 -0800 (Sat, 17 Feb 2018)
New Revision: 16383
   trunk/liblwgeom/cunit/cu_lwstroke.c
   trunk/liblwgeom/cunit/cu_ptarray.c
   trunk/liblwgeom/lwstroke.c
   trunk/liblwgeom/ptarray.c
Patch by Raúl Marín Rodríguez
Closes https://github.com/postgis/postgis/pull/209
Modified: trunk/liblwgeom/cunit/cu_lwstroke.c
--- trunk/liblwgeom/cunit/cu_lwstroke.c	2018-02-17 08:42:21 UTC (rev 16382)
+++ trunk/liblwgeom/cunit/cu_lwstroke.c	2018-02-17 08:46:20 UTC (rev 16383)
@@ -294,12 +294,12 @@
 	in = lwgeom_from_text("CIRCULARSTRING(71.96 -65.64,22.2 -18.52,20 50)");
 	out = lwcurve_linearize(in, M_PI/4.0,
-													 LW_LINEARIZE_TOLERANCE_TYPE_MAX_ANGLE,
-													 LW_LINEARIZE_FLAG_SYMMETRIC);
+			 LW_LINEARIZE_TOLERANCE_TYPE_MAX_ANGLE,
+			 LW_LINEARIZE_FLAG_SYMMETRIC);
 	lwgeom_reverse_in_place(in);
 	out2 = lwcurve_linearize(in, M_PI/4.0,
 	lwgeom_reverse_in_place(out2);
 	if ( ! lwgeom_same(out, out2) )
@@ -317,6 +317,153 @@
 	lwgeom_free(in);
+static void test_unstroke()
+	LWGEOM *in, *out;
+	char *str;
+	/* It would be nice if this example returned two arcs (it's the intersection of two circles)
+	   but it looks like the intersection itself is too sloppy in generating the derived point
+	   to accurately reconstruct the circles.
+	in = lwgeom_from_text("POLYGON((0.5 0,0.471177920604846 -0.292635483024192,0.38581929876693 -0.574025148547634,0.247204418453818 -0.833355349529403,0.0606601717798223 -1.06066017177982,-5.44089437167602e-17 -1.11044268820754,-0.0606601717798188 -1.06066017177982,-0.247204418453816 -0.833355349529406,-0.385819298766929 -0.574025148547639,-0.471177920604845 -0.292635483024197,-0.5 -4.84663372329776e-15,-0.471177920604847 0.292635483024187,-0.385819298766932 0.57402514854763,-0.247204418453821 0.833355349529398,-0.0606601717798256 1.06066017177982,3.45538806345173e-16 1.11044268820754,0.0606601717798183 1.06066017177982,0.247204418453816 0.833355349529407,0.385819298766929 0.574025148547638,0.471177920604845 0.292635483024196,0.5 0))");
+	out = lwgeom_unstroke(in);
+	str = lwgeom_to_wkt(out, WKT_ISO, 8, NULL);
+	printf("%s\n", str);
+	ASSERT_STRING_EQUAL(str, "CIRCULARSTRING(-1 0,0 1,0 -1)");
+	lwgeom_free(in);
+	lwgeom_free(out);
+	lwfree(str);
+	in = lwgeom_from_text("CIRCULARSTRING(-1 0,0 1,0 -1)");
+	out = lwgeom_stroke(in,8);
+	lwgeom_free(in);
+	in = out;
+	// printf("%s\n", str);
+	ASSERT_STRING_EQUAL(str, "CIRCULARSTRING(-1 0,0.70710678 0.70710678,0 -1)");
+	lwgeom_free(in);
+	lwgeom_free(out);
+	lwfree(str);
+	in = lwgeom_from_text("COMPOUNDCURVE(CIRCULARSTRING(-1 0,0 1,0 -1),(0 -1,-1 -1))");
+	lwgeom_free(in);
+	in = out;
+	ASSERT_STRING_EQUAL(str, "COMPOUNDCURVE(CIRCULARSTRING(-1 0,0.70710678 0.70710678,0 -1),(0 -1,-1 -1))");
+	lwgeom_free(in);
+	lwgeom_free(out);
+	lwfree(str);
+	in = lwgeom_from_text("COMPOUNDCURVE((-3 -3,-1 0),CIRCULARSTRING(-1 0,0 1,0 -1),(0 -1,0 -1.5,0 -2),CIRCULARSTRING(0 -2,-1 -3,1 -3),(1 -3,5 5))");
+	lwgeom_free(in);
+	in = out;
+	    str,
+	    "COMPOUNDCURVE((-3 -3,-1 0),CIRCULARSTRING(-1 0,0.70710678 "
+	    "0.70710678,0 -1),(0 -1,0 -1.5,0 -2),CIRCULARSTRING(0 "
+	    "-2,-0.70710678 -3.70710678,1 -3),(1 -3,5 5))");
+	lwgeom_free(in);
+	lwgeom_free(out);
+	lwfree(str);
+	in = lwgeom_from_text("COMPOUNDCURVE(CIRCULARSTRING(-1 0,0 1,0 -1),CIRCULARSTRING(0 -1,-1 -2,1 -2))");
+	lwgeom_free(in);
+	in = out;
+	    str,
+	    "COMPOUNDCURVE(CIRCULARSTRING(-1 0,0.70710678 0.70710678,0 "
+	    "-1),CIRCULARSTRING(0 -1,-0.70710678 -2.70710678,1 -2))");
+	lwgeom_free(in);
+	lwgeom_free(out);
+	lwfree(str);
+	in = lwgeom_from_text("COMPOUNDCURVE((0 0, 1 1), CIRCULARSTRING(1 1, 2 2, 3 1), (3 1, 4 4))");
+	lwgeom_free(in);
+	in = out;
+	ASSERT_STRING_EQUAL(str, "COMPOUNDCURVE((0 0,1 1),CIRCULARSTRING(1 1,2 2,3 1),(3 1,4 4))");
+	lwgeom_free(in);
+	lwgeom_free(out);
+	lwfree(str);
+	// See http://trac.osgeo.org/postgis/ticket/2425
+	// and http://trac.osgeo.org/postgis/ticket/2420
+	in = lwgeom_from_text("LINESTRING(0 0,10 0,10 10,0 10,0 0)");
+	ASSERT_STRING_EQUAL(str, "LINESTRING(0 0,10 0,10 10,0 10,0 0)");
+	lwgeom_free(in);
+	lwgeom_free(out);
+	lwfree(str);
+	in = lwgeom_from_text("LINESTRING(10 10,0 10,0 0,10 0)");
+	ASSERT_STRING_EQUAL(str, "LINESTRING(10 10,0 10,0 0,10 0)");
+	lwgeom_free(in);
+	lwgeom_free(out);
+	lwfree(str);
+	in = lwgeom_from_text("LINESTRING(0 0,10 0,10 10,0 10)");
+	ASSERT_STRING_EQUAL(str, "LINESTRING(0 0,10 0,10 10,0 10)");
+	lwgeom_free(in);
+	lwgeom_free(out);
+	lwfree(str);
+	// See http://trac.osgeo.org/postgis/ticket/2412
+	in = lwgeom_from_text("LINESTRING(0 0, 1 1)");
+	ASSERT_STRING_EQUAL(str, "LINESTRING(0 0,1 1)");
+	lwgeom_free(in);
+	lwgeom_free(out);
+	lwfree(str);
+	in = lwgeom_from_text("GEOMETRYCOLLECTION(LINESTRING(10 10,10 11),LINESTRING(10 11,11 11),LINESTRING(11 11,10 10))");
+	lwgeom_free(in);
+	in = out;
+	ASSERT_STRING_EQUAL(str, "GEOMETRYCOLLECTION(LINESTRING(10 10,10 11),LINESTRING(10 11,11 11),LINESTRING(11 11,10 10))");
+	lwgeom_free(in);
+	lwgeom_free(out);
+	lwfree(str);
+	in = lwgeom_from_text("GEOMETRYCOLLECTION(LINESTRING(4 4,4 8),CIRCULARSTRING(4 8,6 10,8 8),LINESTRING(8 8,8 4))");
+	lwgeom_free(in);
+	in = out;
+	ASSERT_STRING_EQUAL(str, "GEOMETRYCOLLECTION(LINESTRING(4 4,4 8),CIRCULARSTRING(4 8,6 10,8 8),LINESTRING(8 8,8 4))");
+	lwgeom_free(in);
+	lwgeom_free(out);
+	lwfree(str);
 ** Used by the test harness to register the tests in this file.
@@ -325,4 +472,5 @@
 	CU_pSuite suite = CU_add_suite("lwstroke", NULL, NULL);
 	PG_ADD_TEST(suite, test_lwcurve_linearize);
+	PG_ADD_TEST(suite, test_unstroke);
Modified: trunk/liblwgeom/cunit/cu_ptarray.c
--- trunk/liblwgeom/cunit/cu_ptarray.c	2018-02-17 08:42:21 UTC (rev 16382)
+++ trunk/liblwgeom/cunit/cu_ptarray.c	2018-02-17 08:46:20 UTC (rev 16383)
@@ -340,131 +340,6 @@
-static void test_ptarray_unstroke()
-	LWGEOM *in, *out;
-	char *str;
-	/* It would be nice if this example returned two arcs (it's the intersection of two circles)
-	   but it looks like the intersection itself is too sloppy in generating the derived point
-	   to accurately reconstruct the circles.
-	in = lwgeom_from_text("POLYGON((0.5 0,0.471177920604846 -0.292635483024192,0.38581929876693 -0.574025148547634,0.247204418453818 -0.833355349529403,0.0606601717798223 -1.06066017177982,-5.44089437167602e-17 -1.11044268820754,-0.0606601717798188 -1.06066017177982,-0.247204418453816 -0.833355349529406,-0.385819298766929 -0.574025148547639,-0.471177920604845 -0.292635483024197,-0.5 -4.84663372329776e-15,-0.471177920604847 0.292635483024187,-0.385819298766932 0.57402514854763,-0.247204418453821 0.833355349529398,-0.0606601717798256 1.06066017177982,3.45538806345173e-16 1.11044268820754,0.0606601717798183 1.06066017177982,0.247204418453816 0.833355349529407,0.385819298766929 0.574025148547638,0.471177920604845 0.292635483024196,0.5 0))");
-	out = lwgeom_unstroke(in);
-	str = lwgeom_to_wkt(out, WKT_ISO, 8, NULL);
-	printf("%s\n", str);
-	ASSERT_STRING_EQUAL(str, "CIRCULARSTRING(-1 0,0 1,0 -1)");
-	lwgeom_free(in);
-	lwgeom_free(out);
-	lwfree(str);
-	in = lwgeom_from_text("CIRCULARSTRING(-1 0,0 1,0 -1)");
-	out = lwgeom_stroke(in,8);
-	lwgeom_free(in);
-	in = out;
-	// printf("%s\n", str);
-	ASSERT_STRING_EQUAL(str, "CIRCULARSTRING(-1 0,0.70710678 0.70710678,0 -1)");
-	lwgeom_free(in);
-	lwgeom_free(out);
-	lwfree(str);
-	in = lwgeom_from_text("COMPOUNDCURVE(CIRCULARSTRING(-1 0,0 1,0 -1),(0 -1,-1 -1))");
-	lwgeom_free(in);
-	in = out;
-	ASSERT_STRING_EQUAL(str, "COMPOUNDCURVE(CIRCULARSTRING(-1 0,0.70710678 0.70710678,0 -1),(0 -1,-1 -1))");
-	lwgeom_free(in);
-	lwgeom_free(out);
-	lwfree(str);
-	in = lwgeom_from_text("COMPOUNDCURVE((-3 -3,-1 0),CIRCULARSTRING(-1 0,0 1,0 -1),(0 -1,0 -1.5,0 -2),CIRCULARSTRING(0 -2,-1 -3,1 -3),(1 -3,5 5))");
-	lwgeom_free(in);
-	in = out;
-	    str,
-	    "COMPOUNDCURVE((-3 -3,-1 0),CIRCULARSTRING(-1 0,0.70710678 "
-	    "0.70710678,0 -1),(0 -1,0 -1.5,0 -2),CIRCULARSTRING(0 "
-	    "-2,-0.70710678 -3.70710678,1 -3),(1 -3,5 5))");
-	lwgeom_free(in);
-	lwgeom_free(out);
-	lwfree(str);
-	in = lwgeom_from_text("COMPOUNDCURVE(CIRCULARSTRING(-1 0,0 1,0 -1),CIRCULARSTRING(0 -1,-1 -2,1 -2))");
-	lwgeom_free(in);
-	in = out;
-	    str,
-	    "COMPOUNDCURVE(CIRCULARSTRING(-1 0,0.70710678 0.70710678,0 "
-	    "-1),CIRCULARSTRING(0 -1,-0.70710678 -2.70710678,1 -2))");
-	lwgeom_free(in);
-	lwgeom_free(out);
-	lwfree(str);
-	in = lwgeom_from_text("COMPOUNDCURVE((0 0, 1 1), CIRCULARSTRING(1 1, 2 2, 3 1), (3 1, 4 4))");
-	lwgeom_free(in);
-	in = out;
-	ASSERT_STRING_EQUAL(str, "COMPOUNDCURVE((0 0,1 1),CIRCULARSTRING(1 1,2 2,3 1),(3 1,4 4))");
-	lwgeom_free(in);
-	lwgeom_free(out);
-	lwfree(str);
-	// See http://trac.osgeo.org/postgis/ticket/2425
-	// and http://trac.osgeo.org/postgis/ticket/2420
-	in = lwgeom_from_text("LINESTRING(0 0,10 0,10 10,0 10,0 0)");
-	ASSERT_STRING_EQUAL(str, "LINESTRING(0 0,10 0,10 10,0 10,0 0)");
-	lwgeom_free(in);
-	lwgeom_free(out);
-	lwfree(str);
-	in = lwgeom_from_text("LINESTRING(10 10,0 10,0 0,10 0)");
-	ASSERT_STRING_EQUAL(str, "LINESTRING(10 10,0 10,0 0,10 0)");
-	lwgeom_free(in);
-	lwgeom_free(out);
-	lwfree(str);
-	in = lwgeom_from_text("LINESTRING(0 0,10 0,10 10,0 10)");
-	ASSERT_STRING_EQUAL(str, "LINESTRING(0 0,10 0,10 10,0 10)");
-	lwgeom_free(in);
-	lwgeom_free(out);
-	lwfree(str);
-	// See http://trac.osgeo.org/postgis/ticket/2412
-	in = lwgeom_from_text("LINESTRING(0 0, 1 1)");
-	ASSERT_STRING_EQUAL(str, "LINESTRING(0 0,1 1)");
-	lwgeom_free(in);
-	lwgeom_free(out);
-	lwfree(str);
 static void test_ptarray_contains_point()
 /* int ptarray_contains_point(const POINTARRAY *pa, const POINT2D *pt, int *winding_number) */
@@ -754,7 +629,6 @@
 	PG_ADD_TEST(suite, test_ptarray_locate_point);
 	PG_ADD_TEST(suite, test_ptarray_isccw);
 	PG_ADD_TEST(suite, test_ptarray_signed_area);
-	PG_ADD_TEST(suite, test_ptarray_unstroke);
 	PG_ADD_TEST(suite, test_ptarray_insert_point);
 	PG_ADD_TEST(suite, test_ptarray_contains_point);
 	PG_ADD_TEST(suite, test_ptarrayarc_contains_point);
Modified: trunk/liblwgeom/lwstroke.c
--- trunk/liblwgeom/lwstroke.c	2018-02-17 08:42:21 UTC (rev 16382)
+++ trunk/liblwgeom/lwstroke.c	2018-02-17 08:46:20 UTC (rev 16383)
@@ -43,6 +43,7 @@
 LWGEOM* lwpolygon_unstroke(const LWPOLY *poly);
 LWGEOM* lwmline_unstroke(const LWMLINE *mline);
 LWGEOM* lwmpolygon_unstroke(const LWMPOLY *mpoly);
+LWGEOM* lwcollection_unstroke(const LWCOLLECTION *c);
 LWGEOM* lwgeom_unstroke(const LWGEOM *geom);
@@ -669,7 +670,7 @@
 			geoms[i] = (LWGEOM *)lwcollection_linearize((LWCOLLECTION *)tmp, tol, type, flags);
 			break;
 		default:
-			geoms[i] = lwgeom_clone(tmp);
+			geoms[i] = lwgeom_clone_deep(tmp);
 			break;
@@ -704,7 +705,7 @@
 		ogeom = (LWGEOM *)lwcollection_linearize((LWCOLLECTION *)geom, tol, type, flags);
 		break;
 	default:
-		ogeom = lwgeom_clone(geom);
+		ogeom = lwgeom_clone_deep(geom);
 	return ogeom;
@@ -993,7 +994,7 @@
 	LWDEBUG(2, "lwline_unstroke called.");
-	if ( line->points->npoints < 4 ) return lwline_as_lwgeom(lwline_clone(line));
+	if ( line->points->npoints < 4 ) return lwline_as_lwgeom(lwline_clone_deep(line));
 	else return pta_unstroke(line->points, line->srid);
@@ -1020,7 +1021,7 @@
 			lwfree(geoms[i]); /* TODO: should this be lwgeom_free instead ? */
-		return lwgeom_clone((LWGEOM *)poly);
+		return lwgeom_clone_deep((LWGEOM *)poly);
 	return (LWGEOM *)lwcollection_construct(CURVEPOLYTYPE, poly->srid, NULL, poly->nrings, geoms);
@@ -1049,7 +1050,7 @@
-		return lwgeom_clone((LWGEOM *)mline);
+		return lwgeom_clone_deep((LWGEOM *)mline);
 	return (LWGEOM *)lwcollection_construct(MULTICURVETYPE, mline->srid, NULL, mline->ngeoms, geoms);
@@ -1077,12 +1078,40 @@
-		return lwgeom_clone((LWGEOM *)mpoly);
+		return lwgeom_clone_deep((LWGEOM *)mpoly);
 	return (LWGEOM *)lwcollection_construct(MULTISURFACETYPE, mpoly->srid, NULL, mpoly->ngeoms, geoms);
 LWGEOM *
+lwcollection_unstroke(const LWCOLLECTION *c)
+	LWCOLLECTION *ret = lwalloc(sizeof(LWCOLLECTION));
+	memcpy(ret, c, sizeof(LWCOLLECTION));
+	if (c->ngeoms > 0)
+		uint32_t i;
+		ret->geoms = lwalloc(sizeof(LWGEOM *)*c->ngeoms);
+		for (i=0; i < c->ngeoms; i++)
+			ret->geoms[i] = lwgeom_unstroke(c->geoms[i]);
+		if (c->bbox)
+			ret->bbox = gbox_copy(c->bbox);
+	else
+		ret->bbox = NULL;
+		ret->geoms = NULL;
+	return (LWGEOM *)ret;
+LWGEOM *
 	LWDEBUG(2, "lwgeom_unstroke called.");
@@ -1097,8 +1126,10 @@
 		return lwmline_unstroke((LWMLINE *)geom);
 	case MULTIPOLYGONTYPE:
 		return lwmpolygon_unstroke((LWMPOLY *)geom);
+	case COLLECTIONTYPE:
+		return lwcollection_unstroke((LWCOLLECTION *)geom);
 	default:
-		return lwgeom_clone(geom);
+		return lwgeom_clone_deep(geom);
Modified: trunk/liblwgeom/ptarray.c
--- trunk/liblwgeom/ptarray.c	2018-02-17 08:42:21 UTC (rev 16382)
+++ trunk/liblwgeom/ptarray.c	2018-02-17 08:46:20 UTC (rev 16383)
@@ -653,7 +653,7 @@
 	POINTARRAY *out = lwalloc(sizeof(POINTARRAY));
-	LWDEBUG(3, "ptarray_clone_deep called.");
+	LWDEBUG(3, "ptarray_clone called.");
 	out->flags = in->flags;
 	out->npoints = in->npoints;
