[postgis-tickets] [PostGIS] #4016: tickets test fails with proj 5.0.0-rc2
PostGIS trac at osgeo.org
Tue Feb 20 06:00:58 PST 2018
  Reporter:  Bas Couwenberg  |      Owner:  pramsey
      Type:  defect          |     Status:  closed
  Priority:  medium          |  Milestone:  PostGIS 2.4.4
 Component:  postgis         |    Version:  2.4.x
Resolution:  fixed           |   Keywords:
Changes (by komzpa):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"16388" 16388]:
 #!CommitTicketReference repository="" revision="16388"
 PROJ: Cleanup point4d_transform and lwproj_from_string
 Patch by Raúl Marín Rodríguez
 Closes https://github.com/postgis/postgis/pull/212
 Closes #4016
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4016#comment:9>
