[postgis-tickets] [PostGIS] #4016: tickets test fails with proj 5.0.0-rc2
PostGIS trac at osgeo.org
Tue Feb 20 04:23:18 PST 2018
  Reporter:  Bas Couwenberg  |      Owner:  pramsey
      Type:  defect          |     Status:  new
  Priority:  medium          |  Milestone:  PostGIS 2.4.4
 Component:  postgis         |    Version:  2.4.x
Resolution:                  |   Keywords:
Comment (by Algunenano):
 The fix has been introduced before the final PROJ 5 released, so the
 hotfix isn't needed in PostGIS.
 As I was already there, I've broken down the long error strings and
 simplified `lwproj_from_string` since there is already a proj function
 that does all that. PR to finally close the issue:
 https://github.com/postgis/postgis/pull/212
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4016#comment:8>
