[postgis-tickets] [PostGIS] #4026: Memory leaks in test_rect_tree_contains_point
trac at osgeo.org
Wed Feb 21 02:46:11 PST 2018
Reporter: Algunenano | Owner: Algunenano
Type: defect | Status: assigned
Priority: medium | Milestone: PostGIS 2.5.0
Component: liblwgeom | Version: trunk
Keywords: |
==2979==ERROR: LeakSanitizer: detected memory leaks
Direct leak of 128 byte(s) in 1 object(s) allocated from:
#0 0x55ff8a5fd3c1 in __interceptor_malloc
(/home/raul/dev/public/postgis/liblwgeom/cunit/.libs/lt-
cu_tester+0x13b3c1)
#1 0x7faf98a0394b in rect_node_internal_new
/home/raul/dev/public/postgis/liblwgeom/lwtree.c:566:20
#2 0x7faf98a0394b in rect_nodes_merge
/home/raul/dev/public/postgis/liblwgeom/lwtree.c:604
#3 0x7faf98a0394b in rect_tree_from_lwcurvepoly
/home/raul/dev/public/postgis/liblwgeom/lwtree.c:803
#4 0x7faf98a0394b in rect_tree_from_lwgeom
/home/raul/dev/public/postgis/liblwgeom/lwtree.c:868
#5 0x55ff8a653495 in test_rect_tree_contains_point
/home/raul/dev/public/postgis/liblwgeom/cunit/cu_measures.c:212:9
SUMMARY: AddressSanitizer: 4856 byte(s) leaked in 40 allocation(s).
GH PR: https://github.com/postgis/postgis/pull/216
I'll see if I can push this myself.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4026>
