[postgis-tickets] [PostGIS] #4026: Memory leaks in test_rect_tree_contains_point
trac at osgeo.org
Tue Feb 27 09:42:56 PST 2018
Reporter: Algunenano | Owner: Algunenano
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.5.0
Component: liblwgeom | Version: trunk
Resolution: fixed | Keywords:
Changes (by Raul Marin):
* status: assigned => closed
* resolution: => fixed
Comment:
In [changeset:"16434" 16434]:
#!CommitTicketReference repository="" revision="16434"
test_rect_tree_contains_point: Fix memory leaks
Closes #4026
Closes https://github.com/postgis/postgis/pull/216
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4026#comment:1>
