[postgis-tickets] r16422 - Fix memory corruption in case where lexer is interrupted mid-process
Paul Ramsey
pramsey at cleverelephant.ca
Mon Feb 26 11:51:25 PST 2018
Author: pramsey
Date: 2018-02-26 11:51:25 -0800 (Mon, 26 Feb 2018)
New Revision: 16422
trunk/liblwgeom/lwin_wkt_lex.l
References #4017
Modified: trunk/liblwgeom/lwin_wkt_lex.l
--- trunk/liblwgeom/lwin_wkt_lex.l 2018-02-26 18:27:03 UTC (rev 16421)
+++ trunk/liblwgeom/lwin_wkt_lex.l 2018-02-26 19:51:25 UTC (rev 16422)
@@ -10,24 +10,7 @@
static YY_BUFFER_STATE wkt_yy_buf_state;
-* Set up the lexer!
-void wkt_lexer_init(char *src)
- wkt_yy_buf_state = wkt_yy_scan_string(src);
-* Clean up the lexer!
-void wkt_lexer_close()
- wkt_yy_delete_buffer(wkt_yy_buf_state);
* Handle errors due to unexpected junk in WKT strings.
static void wkt_lexer_unknown()
@@ -38,7 +21,6 @@
global_parser_result.errlocation = wkt_yylloc.last_column;
* This macro is magically run after a rule is found but before the main
* action is run. We use it to update the parse location information
@@ -129,4 +111,21 @@
void wkt_yyfree (void * ptr )
lwfree( (char *) ptr ); /* see wkt_yyrealloc() for (char *) cast */
\ No newline at end of file
+* Set up the lexer!
+void wkt_lexer_init(char *src)
+ wkt_yy_buf_state = wkt_yy_scan_string(src);
+* Clean up the lexer!
+void wkt_lexer_close()
+ wkt_yy_delete_buffer(wkt_yy_buf_state);
