[postgis-tickets] r16424 - Fix memory corruption in case where lexer is interrupted mid-process
Paul Ramsey
pramsey at cleverelephant.ca
Mon Feb 26 12:03:29 PST 2018
Author: pramsey
Date: 2018-02-26 12:03:28 -0800 (Mon, 26 Feb 2018)
New Revision: 16424
branches/2.4/NEWS
branches/2.4/liblwgeom/lwin_wkt_lex.l
References #4017
For 2.4 branch
Modified: branches/2.4/NEWS
--- branches/2.4/NEWS 2018-02-26 19:52:01 UTC (rev 16423)
+++ branches/2.4/NEWS 2018-02-26 20:03:28 UTC (rev 16424)
@@ -10,6 +10,7 @@
- #3942, geojson: Do not include private header for json-c >= 0.13
(Björn Esser)
- #4025, Incorrect answers for temporally "amost overlapping" ranges
+ - #4017, lwgeom lexer memory corruption (Peter E)
* Enhancements *
- #3992, Use PKG_PROG_PKG_CONFIG macro from pkg.m4 to detect pkg-config
Modified: branches/2.4/liblwgeom/lwin_wkt_lex.l
--- branches/2.4/liblwgeom/lwin_wkt_lex.l 2018-02-26 19:52:01 UTC (rev 16423)
+++ branches/2.4/liblwgeom/lwin_wkt_lex.l 2018-02-26 20:03:28 UTC (rev 16424)
@@ -10,24 +10,7 @@
static YY_BUFFER_STATE wkt_yy_buf_state;
-* Set up the lexer!
-void wkt_lexer_init(char *src)
- wkt_yy_buf_state = wkt_yy_scan_string(src);
-* Clean up the lexer!
-void wkt_lexer_close()
- wkt_yy_delete_buffer(wkt_yy_buf_state);
* Handle errors due to unexpected junk in WKT strings.
static void wkt_lexer_unknown()
@@ -38,7 +21,6 @@
global_parser_result.errlocation = wkt_yylloc.last_column;
* This macro is magically run after a rule is found but before the main
* action is run. We use it to update the parse location information
@@ -129,4 +111,21 @@
void wkt_yyfree (void * ptr )
lwfree( (char *) ptr ); /* see wkt_yyrealloc() for (char *) cast */
\ No newline at end of file
+* Set up the lexer!
+void wkt_lexer_init(char *src)
+ wkt_yy_buf_state = wkt_yy_scan_string(src);
+* Clean up the lexer!
+void wkt_lexer_close()
+ wkt_yy_delete_buffer(wkt_yy_buf_state);
