[postgis-tickets] [PostGIS] #4068: sfcgal 1.3.3 with CGAL 4.11 doesn't compile against PostGIS
PostGIS trac at osgeo.org
Wed Jul 4 14:15:10 PDT 2018
  Reporter:  robe     |      Owner:  robe
      Type:  defect   |     Status:  closed
  Priority:  blocker  |  Milestone:  PostGIS 2.2.8
 Component:  postgis  |    Version:  2.4.x
Resolution:  fixed    |   Keywords:
Changes (by robe):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 As Bas noted in http://lists.osgeo.org/pipermail/postgis-
 devel/2018-June/027168.html  debian SFCGAL issue is fixed.
 So I went ahead and reinstalled sfcgal on debbie (got 1.3.5) and renabled
 the sfcgal tests on 2.5 branch at r16634.  Looks to be working so I'll go
 ahead and do the same for 2.2, 2.3, and 2.4 branches.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4068#comment:13>
