[postgis-tickets] [PostGIS] #4117: Regress: Failures when some tests are run in parallel mode
PostGIS trac at osgeo.org
Fri Jul 6 06:14:07 PDT 2018
  Reporter:  Algunenano  |      Owner:  Algunenano
      Type:  defect      |     Status:  closed
  Priority:  low         |  Milestone:  PostGIS 2.5.0
 Component:  postgis     |    Version:  trunk
Resolution:  fixed       |   Keywords:
Changes (by Raul Marin):
 * status:  assigned => closed
 * resolution:   => fixed
Comment:
 In [changeset:"16637" 16637]:
 #!CommitTicketReference repository="" revision="16637"
 Adapt regress tests for parallel plans
 Closes #4117
 Closes https://github.com/postgis/postgis/pull/266
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4117#comment:2>
