[postgis-tickets] [PostGIS] #4121: Minor error in PostGIS 2.4.5 dev Manual’s example
trac at osgeo.org
Tue Jul 10 07:11:50 PDT 2018
Reporter: dimishra | Owner: pramsey
Type: defect | Status: new
Priority: low | Milestone: PostGIS 2.4.5
Component: postgis | Version: 2.4.x
Keywords: Postgis Documentation |
I have observed a minor error in PostGIS 2.4.5 dev Manual’s example on
page 33/802 and 34/802.
Going by “gtest” table structure, insert statement should have column name
“GID” instead of ‘ID’.
CREATE TABLE gtest ( **gid** serial primary key, name varchar(20) , geom
geometry(LINESTRING) );
INSERT INTO gtest (**ID**, NAME, GEOM) VALUES (1, 'First
Geometry',ST_GeomFromText ('LINESTRING(2 3,4 5,6 5,7 8)'));
Hope this makes sense!
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4121>
