[postgis-tickets] r16642 - SP-GiST documentation.
Darafei
komzpa at gmail.com
Fri Jul 13 02:07:19 PDT 2018
Author: komzpa
Date: 2018-07-13 14:07:19 -0700 (Fri, 13 Jul 2018)
New Revision: 16642
trunk/doc/using_postgis_dataman.xml
Patch provided by Esteban Zimanyi.
Closes #1847
Modified: trunk/doc/using_postgis_dataman.xml
--- trunk/doc/using_postgis_dataman.xml 2018-07-13 20:06:43 UTC (rev 16641)
+++ trunk/doc/using_postgis_dataman.xml 2018-07-13 21:07:19 UTC (rev 16642)
@@ -2167,6 +2167,53 @@
for kNN searches at the moment.</para>
</sect2>
+ <sect2 id="spgist_indexes">
+ <title>SP-GiST Indexes</title>
+ <para>SP-GiST stands for "Space-Partitioned Generalized Search Tree" and is
+ a generic form of indexing that supports partitioned search trees, such as
+ quad-trees, k-d trees, and radix trees (tries). The common feature of these
+ data structures is that they repeatedly divide the search space into
+ partitions that need not be of equal size. In addition to GIS indexing,
+ SP-GiST is used to speed up searches on many kinds of data, such as phone
+ routing, ip routing, substring search, etc. </para>
+ <para>As it is the case for GiST indexes, SP-GiST indexes are lossy, in the
+ sense that they store the bounding box englobing the spatial objects.
+ SP-GiST indexes can be considered as an alternative to GiST indexes. The
+ performance tests reveal that SP-GiST indexes are especially beneficial
+ when there are many overlapping objects, that is, with so-called
+ “spaghetti data”.</para>
+ <para>Once a GIS data table exceeds a few thousand rows, an SP-GiST index
+ may be used to speed up spatial searches of the data. The syntax for
+ building an SP-GiST index on a "geometry" column is as follows:</para>
+ <para><programlisting>CREATE INDEX [indexname] ON [tablename] USING SPGIST ( [geometryfield] ); </programlisting></para>
+ <para>The above syntax will build a 2-dimensional index. A 3-dimensional
+ index for the geometry type can be created using the 3D operator class:</para>
+ <para><programlisting>CREATE INDEX [indexname] ON [tablename] USING SPGIST ([geometryfield] spgist_geometry_ops_3d);</programlisting></para>
+ <para>Building a spatial index is a computationally intensive operation.
+ It also blocks write access to your table for the time it creates, so on a
+ production system you may want to do in in a slower CONCURRENTLY-aware way:</para>
+ <para><programlisting>CREATE INDEX CONCURRENTLY [indexname] ON [tablename] USING SPGIST ( [geometryfield] ); </programlisting></para>
+ <para>After building an index, it is sometimes helpful to force PostgreSQL to
+ collect table statistics, which are used to optimize query plans:</para>
+ <para><programlisting>VACUUM ANALYZE [table_name] [(column_name)];</programlisting></para>
+ <para>An SP-GiST index can accelerate queries involving the following operators:</para>
+ <itemizedlist>
+ <listitem><para><<, &<, &>, >>, <<|, &<|, |&>, |>>, &&, @>, <@, and ~=, for 2-dimensional indexes,</para></listitem>
+ <listitem><para> &/&, ~==, @>>, and <<@, for 3-dimensional indexes.</para></listitem>
+ </itemizedlist>
+ <para>There is no support for kNN searches at the moment.</para>
+ </sect2>
<sect2>
<title>Using Indexes</title>
