[postgis-tickets] [PostGIS] #4121: Minor error in PostGIS 2.4.5 dev Manual’s example
PostGIS trac at osgeo.org
Fri Jul 13 14:20:01 PDT 2018
  Reporter:  dimishra  |      Owner:  komzpa
      Type:  defect    |     Status:  closed
  Priority:  low       |  Milestone:  PostGIS 2.4.5
 Component:  postgis   |    Version:  2.4.x
Resolution:  fixed     |   Keywords:  Postgis Documentation
Changes (by komzpa):
 * status:  assigned => closed
 * resolution:   => fixed
Comment:
 In [changeset:"16643" 16643]:
 #!CommitTicketReference repository="" revision="16643"
 Sync column names in example.
 Closes #4121
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4121#comment:2>
