[postgis-tickets] r16644 - Fix postgis_tiger_geocoder.control generation
Darafei
komzpa at gmail.com
Fri Jul 13 04:30:57 PDT 2018
Author: komzpa
Date: 2018-07-13 16:30:57 -0700 (Fri, 13 Jul 2018)
New Revision: 16644
trunk/configure.ac
Patch by Christoph Berg
Commit 639308e moved the postgis_tiger_geocoder.control into the
Makefile, but forgot to remove the file from configure.ac, which still
generates the file, so the Makefile rule is not effective and the
resulting .control file has the raw @EXTVERSION@ line from the .in file.
Closes #4123
Closes https://github.com/postgis/postgis/pull/270
Modified: trunk/configure.ac
--- trunk/configure.ac 2018-07-13 21:20:00 UTC (rev 16643)
+++ trunk/configure.ac 2018-07-13 23:30:57 UTC (rev 16644)
@@ -1459,7 +1459,6 @@
extensions/postgis_sfcgal/Makefile
extensions/postgis_topology/Makefile
extensions/postgis_tiger_geocoder/Makefile
- extensions/postgis_tiger_geocoder/postgis_tiger_geocoder.control
extensions/address_standardizer/Makefile
liblwgeom/Makefile
liblwgeom/cunit/Makefile
