[postgis-tickets] [PostGIS] #3888: Split core and raster extensions
trac at osgeo.org
Mon Jul 16 14:20:18 PDT 2018
Reporter: strk | Owner: strk
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 3.0.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by strk):
The gitea PR (which includes upgrade tests) is green:
https://git.osgeo.org/gitea/postgis/postgis/pulls/20
GitLab PR is also green:
https://gitlab.com/postgis/postgis/merge_requests/6
Current state of branch is that on upgrade you get raster unpackaged and a
WARNING message telling you to either repackage (if needed) or drop (if
unneeded):
test=# alter extension postgis update;
WARNING: unpackaging raster
WARNING: PostGIS Raster functionality have been unpackaged
HINT: type `CREATE EXTENSION postgis_raster FROM unpackaged` to re-
package or source `uninstall_rtpostgis.sql` to drop.
WARNING: 'postgis.backend' is already set and cannot be changed until you
reconnect
ALTER EXTENSION
Regina suggested to directly drop the unpackaged raster but I'm not sure
how we can tell if that support is still needed by the caller.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3888#comment:21>
