[postgis-tickets] [PostGIS] #4126: sfcgal/concave_hull on sid/i386/PG10: ERROR: GeometryCollection is invalid : Polygon 12 is invalid: not enough points in ring 0
trac at osgeo.org
Tue Jul 17 05:37:58 PDT 2018
Reporter: myon | Owner: colivier
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.5.0
Component: sfcgal | Version: trunk
Keywords: |
On Debian unstable i386, the sfcgal/concave_hull test fails:
--- sfcgal/concave_hull_expected 2018-07-17 09:54:38.613988675
+0200
+++ /tmp/pgis_reg/test_135_out 2018-07-17 14:26:52.805277571 +0200
@@ -1,3 +1,9 @@
ST_ConcaveHull MultiPolygon 0.95|t|t
-ST_ConcaveHull Lines 0.80|t|t
-ST_ConcaveHull Lines 0.80 holes|t|t
+NOTICE: During union(A,B) :
+NOTICE: with A: MULTILINESTRING((36/1
150/1,2131446508051805/35184372088832 150/1,134214654424097/2199023255552
150/1,62/1 150/1,4455510276405451/70368744177664
2602430424116217/17592186044416,4502864889160195/70368744177664
1291913413124141/8796093022208),(2726116527791431/70368744177664
518882869217331/4398046511104,169052008875667/4398046511104
64746585208437/549755813888,2691756561183829/70368744177664
2069654114160129/17592186044416),(1682017803923229/35184372088832
3342639698202655/35184372088832,1682549074047135/35184372088832
417766572090093/4398046511104,3437184779155767/70368744177664
3307727593714121/35184372088832),(3437184779155767/70368744177664
3307727593714121/35184372088832,3440352856007001/70368744177664
1653107778517561/17592186044416),(3440352856007001/70368744177664
1653107778517561/17592186044416,430045447634487/8796093022208
3306210438252241/35184372088832),(1877727914546985/35184372088832
2761046010532207/17592186044416,1868744718964359/35184372088832
2759249371415681/17592186044416,36/1
150/1),(3810878897050701/70368744177664
345823539665985/2199023255552,1877727914546985/35184372088832
2761046010532207/17592186044416),(4502864889160195/70368744177664
1291913413124141/8796093022208,76/1 128/1),(9791971818841/137438953472
616698163838769/4398046511104,2726116527791431/70368744177664
518882869217331/4398046511104),(314791216158603/4398046511104
1235377962774799/8796093022208,9791971818841/137438953472
616698163838769/4398046511104),(316819925148861/4398046511104
1238154090866731/8796093022208,314791216158603/4398046511104
1235377962774799/8796093022208),(76/1 128/1,177712060840369/2199023255552
4362449048458269/35184372088832),(177712060840369/2199023255552
4362449048458269/35184372088832,2852896801588495/35184372088832
4354529191672777/35184372088832))
+NOTICE: and B:
GEOMETRYCOLLECTION(LINESTRING(2721869834906585/70368744177664
4149610137751727/35184372088832,169052008875667/4398046511104
2069654114160129/17592186044416),LINESTRING(1566967376199059/35184372088832
4290579714788305/35184372088832,44390303992691/1099511627776
2095179082930249/17592186044416),LINESTRING(1604911186611371/35184372088832
676620666236271/4398046511104,36/1
150/1),LINESTRING(8399886231012701/140737488355328
150/1),LINESTRING(2131446508051805/35184372088832
150/1),LINESTRING(134214654424097/2199023255552 150/1,62/1
150/1),LINESTRING(62/1 150/1,4455510276405451/70368744177664
2602430424116217/17592186044416),LINESTRING(4455510276405451/70368744177664
1291913413124141/8796093022208),LINESTRING(4502864889160195/70368744177664
1291913413124141/8796093022208,1130453900949095/17592186044416
1288190951320605/8796093022208),LINESTRING(316819925148861/4398046511104
1238154090866731/8796093022208,2523129955564389/35184372088832
618099527057415/4398046511104),LINESTRING(1400220849639383/17592186044416
1099560444232721/8796093022208,177712060840369/2199023255552
4362449048458269/35184372088832),LINESTRING(177712060840369/2199023255552
4354529191672777/35184372088832),POLYGON((430045447634487/8796093022208
3306210438252241/35184372088832,430045447634487/8796093022208
3306210438252241/35184372088832)),POLYGON((430045447634487/8796093022208
3306210438252241/35184372088832,5600883398557533/70368744177664
1099560444232721/8796093022208,5653338500867261/70368744177664
8752770968603661/70368744177664,2852896801588495/35184372088832
4354529191672777/35184372088832,2747521139158397/35184372088832
8884684487395717/70368744177664,2572125026543451/35184372088832
582963520819269/4398046511104,316819925148861/4398046511104
+ERROR: GeometryCollection is invalid : Polygon 12 is invalid: not enough
points in ring 0 :
+NOTICE: and B:
points in ring 0 :
* Debian unstable i386
* PostgreSQL 10.4-2.pgdg+1
* POSTGIS="2.5.0beta2dev r16647" [EXTENSION] PGSQL="100"
GEOS="3.6.2-CAPI-1.10.2 4d2925d6" PROJ="Rel. 5.1.0, June 1st, 2018"
GDAL="GDAL 2.3.1, released 2018/06/22" LIBXML="2.9.4" LIBJSON="0.12.1"
LIBPROTOBUF="1.2.1" RASTER
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4126>
