[postgis-tickets] [PostGIS] #4130: PostGIS and GDAL: ST_AsGDALRaster doesn't work
trac at osgeo.org
Fri Jul 20 08:59:41 PDT 2018
Reporter: lerocchi | Owner: pramsey
Type: defect | Status: new
Priority: critical | Milestone: PostGIS 2.4.5
Component: postgis | Version: 2.4.x
Keywords: |
ST_AsGDALRaster doesn't work when using specific GDAL Format (e.g. WMS or
RST).
When I run this query:
select ST_AsGDALRaster(rast,'WMS') from my_raster
I will get the error: ERROR: rt_raster_to_gdal: Could not create the
output GDAL dataset
The error occurs on Ubuntu 16.04 with Postgresql 10 and Postgis 2.4.
In order to enable all GDAL drivers I run
ALTER DATABASE gisdb SET postgis.gdal_datapath = '/usr/share/gdal/2.2';
ALTER DATABASE gisdb SET postgis.gdal_enabled_drivers TO 'ENABLE_ALL';
ALTER DATABASE gisdb SET postgis.postgis.enable_outdb_rasters TO true;
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4130>
