[postgis-tickets] [PostGIS] #3994: FreeBSD 32 failure on raster tests
PostGIS trac at osgeo.org
Sat Jul 21 07:20:53 PDT 2018
  Reporter:  robe    |      Owner:  Bborie Park
      Type:  defect  |     Status:  new
  Priority:  medium  |  Milestone:  PostGIS 2.5.0
 Component:  raster  |    Version:  trunk
Resolution:          |   Keywords:
Comment (by komzpa):
 In [changeset:"16654" 16654]:
 #!CommitTicketReference repository="" revision="16654"
 32bit allocations are 4-byte aligned, not 8-byte aligned.
 Fix 8-bit alignment assumption in padding to match assert.
 Passes tests on 32bit Ubuntu Artful.
 References #3994
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3994#comment:4>
