[postgis-tickets] [PostGIS] #4125: postgis 2.5 crashes with PG11 on Debian stretch/amd64
trac at osgeo.org
Sat Jul 21 12:40:37 PDT 2018
Reporter: myon | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.5.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by komzpa):
More symbols:
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
Core was generated by `postgres: 11/main: root postgis_reg [local] SELECT
Program terminated with signal SIGSEGV, Segmentation fault.
#0 0x00007faedc0282de in ?? () from /lib/x86_64-linux-gnu/libgcc_s.so.1
Thread 1 (Thread 0x7faee2354900 (LWP 1276)):
#1 0x00007faedc0287d9 in ?? () from /lib/x86_64-linux-gnu/libgcc_s.so.1
#2 0x00007faedc029076 in _Unwind_Find_FDE () from /lib/x86_64-linux-
gnu/libgcc_s.so.1
#3 0x00007faedc025b13 in ?? () from /lib/x86_64-linux-gnu/libgcc_s.so.1
#4 0x00007faedc026d30 in ?? () from /lib/x86_64-linux-gnu/libgcc_s.so.1
#5 0x00007faedc0271de in _Unwind_RaiseException () from /lib/x86_64
#6 0x00007faedc2bd2bc in __cxa_throw () from /usr/lib/x86_64-linux-
gnu/libstdc++.so.6
#7 0x00007faecf2b1dbc in geos::geom::LinearRing::validateConstruction()
() from /usr/lib/x86_64-linux-gnu/libgeos-3.5.1.so
#8 0x00007faecf2b1f3b in
geos::geom::LinearRing::LinearRing(geos::geom::CoordinateSequence*,
geos::geom::GeometryFactory const*) () from /usr/lib/x86_64-linux-
#9 0x00007faecf2af6f5 in
geos::geom::GeometryFactory::createLinearRing(geos::geom::CoordinateSequence*)
const () from /usr/lib/x86_64-linux-gnu/libgeos-3.5.1.so
#10 0x00007faed0634a7a in GEOSGeom_createLinearRing_r () from
/usr/lib/x86_64-linux-gnu/libgeos_c.so.1
#11 0x00007faed08d9e00 in ptarray_to_GEOSLinearRing (autofix=<optimized
out>, pa=<optimized out>) at lwgeom_geos.c:304
#12 LWGEOM2GEOS (lwgeom=0x55967cde1de8, autofix=<optimized out>) at
lwgeom_geos.c:426
#13 0x00007faed08d9d09 in LWGEOM2GEOS (lwgeom=lwgeom at entry=0x55967cde1d80,
autofix=autofix at entry=0 '\000') at lwgeom_geos.c:467
#14 0x00007faed08722cd in isvalid (fcinfo=0x55967ce42350) at
lwgeom_geos.c:1414
#15 0x000055967ac52b11 in ExecInterpExpr (state=0x55967ce42270,
econtext=0x55967ce42b70, isnull=<optimized out>) at
./build/../src/backend/executor/execExprInterp.c:678
#16 0x000055967ad0a59b in ExecEvalExprSwitchContext
(isNull=0x7ffed2780e74, econtext=<optimized out>, state=0x55967ce42270) at
./build/../src/include/executor/executor.h:303
#17 evaluate_expr (expr=<optimized out>, result_type=result_type at entry=16,
result_typmod=result_typmod at entry=-1,
result_collation=result_collation at entry=0) at
./build/../src/backend/optimizer/util/clauses.c:4880
#18 0x000055967ad0de83 in evaluate_function (context=0x7ffed27811f0,
func_tuple=0x7faee22b1408, funcvariadic=false, args=0x55967ce49078,
input_collid=0, result_collid=0, result_typmod=-1, result_type=16,
funcid=79732) at ./build/../src/backend/optimizer/util/clauses.c:4422
#19 simplify_function (funcid=79732, result_type=16, result_typmod=-1,
result_collid=result_collid at entry=0, input_collid=input_collid at entry=0,
args_p=args_p at entry=0x7ffed2781010, funcvariadic=false, process_args=true,
allow_non_const=true, context=0x7ffed27811f0) at
./build/../src/backend/optimizer/util/clauses.c:4062
#20 0x000055967ad0c9ea in eval_const_expressions_mutator
(node=0x55967cd09fd0, context=0x7ffed27811f0) at
./build/../src/backend/optimizer/util/clauses.c:2674
#21 0x000055967aca50cf in expression_tree_mutator
(node=node at entry=0x55967ce47fd0, mutator=mutator at entry=0x55967ad0c740
<eval_const_expressions_mutator>, context=context at entry=0x7ffed27811f0) at
./build/../src/backend/nodes/nodeFuncs.c:3033
#22 0x000055967ad0c7a2 in eval_const_expressions_mutator
(node=0x55967ce47fd0, context=0x7ffed27811f0) at
./build/../src/backend/optimizer/util/clauses.c:3669
#23 0x000055967aca533b in expression_tree_mutator
(node=node at entry=0x55967cd091f0, mutator=mutator at entry=0x55967ad0c740
./build/../src/backend/nodes/nodeFuncs.c:2914
#24 0x000055967ad0c7a2 in eval_const_expressions_mutator
(node=0x55967cd091f0, context=context at entry=0x7ffed27811f0) at
#25 0x000055967ad0dccf in eval_const_expressions
(root=root at entry=0x55967cd09bc0, node=<optimized out>) at
./build/../src/backend/optimizer/util/clauses.c:2472
#26 0x000055967acf5347 in preprocess_expression
(root=root at entry=0x55967cd09bc0, expr=<optimized out>, kind=kind at entry=1)
at ./build/../src/backend/optimizer/plan/planner.c:1041
#27 0x000055967acfb98b in subquery_planner
(glob=glob at entry=0x55967ce496c8, parse=parse at entry=0x55967cd09020,
parent_root=parent_root at entry=0x0, hasRecursion=hasRecursion at entry=false,
tuple_fraction=tuple_fraction at entry=0) at
./build/../src/backend/optimizer/plan/planner.c:732
#28 0x000055967acfcca5 in standard_planner (parse=0x55967cd09020,
cursorOptions=256, boundParams=<optimized out>) at
./build/../src/backend/optimizer/plan/planner.c:405
#29 0x000055967ada7150 in pg_plan_query
(querytree=querytree at entry=0x55967cd09020,
cursorOptions=cursorOptions at entry=256, boundParams=boundParams at entry=0x0)
at ./build/../src/backend/tcop/postgres.c:809
#30 0x000055967ada7226 in pg_plan_queries (querytrees=<optimized out>,
at ./build/../src/backend/tcop/postgres.c:875
#31 0x000055967ada773e in exec_simple_query (query_string=0x55967cf74678
"SELECT '#408.3',
st_isvalid('0106000020BB0B000001000000010300000005000000D6", '0' <repeats
12 times>,
"C0F1A138410AD7A3103190524114AE4721F7A138410000000030905241713D0A57FAA1384185EB51982C9052417B14AE87FAA138410000004"...)
at ./build/../src/backend/tcop/postgres.c:1050
#32 0x000055967ada9473 in PostgresMain (argc=<optimized out>,
argv=argv at entry=0x55967cd50208, dbname=<optimized out>,
username=<optimized out>) at ./build/../src/backend/tcop/postgres.c:4153
#33 0x000055967aab8910 in BackendRun (port=0x55967cd48770) at
./build/../src/backend/postmaster/postmaster.c:4361
#34 BackendStartup (port=0x55967cd48770) at
./build/../src/backend/postmaster/postmaster.c:4033
#35 ServerLoop () at ./build/../src/backend/postmaster/postmaster.c:1706
#36 0x000055967ad34ff3 in PostmasterMain (argc=5, argv=0x55967cd02e40) at
./build/../src/backend/postmaster/postmaster.c:1379
#37 0x000055967aab9e04 in main (argc=5, argv=0x55967cd02e40) at
./build/../src/backend/main/main.c:228
Highly similar stacktrace I see in PG11 on travis, PR:
https://github.com/postgis/postgis/pull/262
Another thing I notice is that clang is used there to emit llvm code:
/usr/bin/clang-3.9 -Wno-ignored-attributes -fno-strict-aliasing -fwrapv
-O2 -I../liblwgeom -g -O1 -I../libpgcommon -I/usr/include
-I/usr/include/libxml2 -I/usr/include -DHAVE_SFCGAL -fPIC
-I/usr/include -DHAVE_SFCGAL -I. -I./ -I/usr/include/postgresql/11/server
-I/usr/include/postgresql/internal -I/usr/include/x86_64-linux-gnu
-D_FORTIFY_SOURCE=2 -D_GNU_SOURCE -I/usr/include/libxml2 -I/usr/include
/mit-krb5 -flto=thin -emit-llvm -c -o postgis_module.bc postgis_module.c
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4125#comment:6>
