[postgis-tickets] [PostGIS] #4131: ConcaveHull sfcgal test lost
trac at osgeo.org
Sat Jul 21 22:00:47 PDT 2018
Reporter: komzpa | Owner: robe
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.5.0
Component: postgis | Version: trunk
Resolution: fixed | Keywords:
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
In [changeset:"16659" 16659]:
#!CommitTicketReference repository="" revision="16659"
put back old sfcgal test (except use \i, and have the query be what was in
sfcgal one), the sfcgal one was different
Closes #4131
Revise ST_ConcaveHull to use ST_UnaryUnion(ST_Collect..) (cause I know
sfcgal doesn't replace with it's own implementation / a bit of a cheat)
Take out some ST_Union calls I think are over compensating.
References #3638
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4131#comment:3>
