[postgis-tickets] [PostGIS] #4109: WKT parser accepting and interpreting numbers with multiple dots
PostGIS trac at osgeo.org
Mon Jul 23 04:25:11 PDT 2018
  Reporter:  strk     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 2.5.0
 Component:  postgis  |    Version:  trunk
Resolution:           |   Keywords:
Comment (by Algunenano):
 Seems like the issue comes from ignoring `WHITESPACE`s in the coordinate
 declaration and supporting numbers as `.5` (0.5):
 # select ST_AsEWKT('LINESTRING(.1 .2, .3 .4)'::geometry);
           st_asewkt
  LINESTRING(0.1 0.2,0.3 0.4)
 (1 row)
 # select ST_AsEWKT('LINESTRING(.1.2, .3.4)'::geometry);
           st_asewkt
 (1 row)
 This probably goes back to 2010.
 I've given it a try in https://github.com/postgis/postgis/pull/277
 After the change:
 ERROR:  parse error - invalid geometry
 LINE 1: select ST_AsEWKT('LINESTRING(.1.2, .3.4)'::geometry);
 HINT:  "LINESTRING(.1.2," <-- parse error at position 16 within geometry
 The main problem is that some other matching rules had to be modified to
 now accept optional whitespaces before or after the main string. It'd nice
 if someone with experience with Bison (or other parsers) could have a look
 to see how it can be improved, and also because I've relied on the tests
 to check if anything was broken.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4109#comment:2>
