[postgis-tickets] r16662 - Fix WKT parser accepting numbers with multiple dots
Raul
raul at rmr.ninja
Mon Jul 23 08:42:59 PDT 2018
Author: algunenano
Date: 2018-07-23 08:42:59 -0700 (Mon, 23 Jul 2018)
New Revision: 16662
trunk/NEWS
trunk/liblwgeom/cunit/cu_in_wkt.c
trunk/liblwgeom/lwin_wkt_lex.c
trunk/liblwgeom/lwin_wkt_lex.l
Closes #4109
Closes https://github.com/postgis/postgis/pull/277
Modified: trunk/NEWS
--- trunk/NEWS 2018-07-23 00:17:50 UTC (rev 16661)
+++ trunk/NEWS 2018-07-23 15:42:59 UTC (rev 16662)
@@ -6,6 +6,8 @@
- #4120, ST_AsMVTGeom: Clip using tile coordinates (Raúl Marín).
- #4132, ST_Intersection on Raster now works without throwing TopologyException
(Vinícius A.B. Schmidt, Darafei Praliaskouski)
+ - #4109, Fix WKT parser accepting and interpreting numbers numbers with
+ multiple dots (Raúl Marín, Paul Ramsey)
See PostGIS 2.5.0 section for full details
Modified: trunk/liblwgeom/cunit/cu_in_wkt.c
--- trunk/liblwgeom/cunit/cu_in_wkt.c 2018-07-23 00:17:50 UTC (rev 16661)
+++ trunk/liblwgeom/cunit/cu_in_wkt.c 2018-07-23 15:42:59 UTC (rev 16662)
@@ -346,6 +346,40 @@
+static void test_wkt_double(void)
+ LWGEOM_PARSER_RESULT p;
+ int rv = 0;
+ char *wkt = 0;
+ wkt = "LINESTRING(1.1.1, 2.2.2)";
+ lwgeom_parser_result_init(&p);
+ rv = lwgeom_parse_wkt(&p, wkt, LW_PARSER_CHECK_ALL);
+ CU_ASSERT_EQUAL( rv, LW_FAILURE );
+ wkt = "LINESTRING(1.1 .1, 2.2 .2)";
+ CU_ASSERT_EQUAL( rv, LW_SUCCESS );
+ wkt = "LINESTRING( 1.1 .1 , 2.2 .2 )";
+ wkt = "LINESTRING(\n1.1\n.1,\n2.2\n.2\n)";
+ wkt = "LINESTRING(1.1\t.1\t,\t2.2\t.2\t)";
+ lwgeom_parser_result_free(&p);
** Used by test harness to register the tests in this file.
@@ -368,4 +402,5 @@
PG_ADD_TEST(suite, test_wkt_in_tin);
PG_ADD_TEST(suite, test_wkt_in_polyhedralsurface);
PG_ADD_TEST(suite, test_wkt_in_errlocation);
+ PG_ADD_TEST(suite, test_wkt_double);
\ No newline at end of file
Modified: trunk/liblwgeom/lwin_wkt_lex.c
--- trunk/liblwgeom/lwin_wkt_lex.c 2018-07-23 00:17:50 UTC (rev 16661)
+++ trunk/liblwgeom/lwin_wkt_lex.c 2018-07-23 15:42:59 UTC (rev 16662)
@@ -623,27 +623,27 @@
flex_int32_t yy_verify;
flex_int32_t yy_nxt;
-static const flex_int16_t yy_accept[172] =
+static const flex_int16_t yy_accept[173] =
{ 0,
0, 0, 27, 25, 24, 24, 20, 21, 22, 25,
- 25, 1, 23, 25, 25, 25, 25, 19, 25, 25,
- 25, 19, 24, 0, 1, 1, 1, 0, 0, 0,
- 0, 0, 0, 0, 0, 0, 0, 0, 0, 19,
- 0, 1, 0, 0, 0, 0, 0, 0, 0, 0,
- 0, 0, 16, 0, 0, 0, 0, 0, 0, 0,
- 0, 0, 0, 0, 0, 0, 0, 0, 18, 0,
- 0, 0, 17, 0, 0, 0, 0, 0, 0, 0,
- 0, 0, 0, 0, 0, 0, 0, 0, 0, 2,
+ 25, 25, 23, 25, 25, 25, 25, 19, 25, 25,
+ 25, 19, 24, 0, 0, 0, 1, 0, 0, 0,
0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ 19, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ 0, 0, 0, 16, 0, 0, 0, 0, 0, 0,
+ 0, 0, 0, 0, 0, 0, 0, 0, 0, 18,
+ 0, 0, 0, 17, 0, 0, 0, 0, 0, 0,
+ 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ 2, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- 10, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- 0, 0, 0, 0, 15, 0, 0, 0, 0, 0,
+ 0, 10, 0, 0, 0, 0, 0, 0, 0, 0,
+ 0, 0, 0, 0, 0, 15, 0, 0, 0, 0,
- 13, 6, 0, 8, 0, 0, 0, 0, 0, 0,
- 0, 0, 0, 0, 0, 0, 0, 9, 0, 0,
- 5, 4, 0, 0, 11, 0, 0, 0, 12, 0,
- 0, 0, 0, 7, 0, 0, 0, 0, 14, 3,
- 0
+ 0, 13, 6, 0, 8, 0, 0, 0, 0, 0,
+ 0, 0, 0, 0, 0, 0, 0, 0, 9, 0,
+ 0, 5, 4, 0, 0, 11, 0, 0, 0, 12,
+ 0, 0, 0, 0, 7, 0, 0, 0, 0, 14,
+ 3, 0
static const YY_CHAR yy_ec[256] =
@@ -688,53 +688,53 @@
1, 1
-static const flex_int16_t yy_base[172] =
+static const flex_int16_t yy_base[173] =
{ 0,
- 0, 0, 353, 366, 51, 53, 366, 366, 366, 48,
- 342, 50, 366, 41, 40, 47, 44, 38, 44, 43,
- 51, 50, 71, 341, 84, 85, 340, 70, 53, 74,
- 72, 77, 79, 81, 84, 86, 88, 86, 90, 366,
- 339, 338, 97, 87, 83, 86, 93, 101, 91, 113,
- 107, 125, 366, 128, 113, 119, 128, 114, 130, 120,
- 128, 121, 132, 335, 129, 132, 125, 130, 366, 129,
- 131, 166, 366, 152, 162, 173, 164, 171, 162, 162,
- 162, 163, 161, 172, 170, 166, 174, 184, 336, 65,
- 180, 177, 201, 197, 189, 202, 198, 202, 206, 202,
+ 0, 0, 202, 384, 51, 53, 384, 384, 384, 48,
+ 190, 57, 384, 41, 41, 52, 49, 42, 48, 48,
+ 56, 53, 75, 186, 0, 96, 384, 106, 109, 54,
+ 62, 61, 80, 86, 91, 97, 100, 102, 100, 104,
+ 384, 179, 126, 112, 102, 105, 109, 117, 129, 120,
+ 126, 119, 136, 384, 139, 124, 130, 140, 127, 144,
+ 134, 142, 135, 148, 85, 141, 154, 148, 154, 384,
+ 157, 160, 195, 384, 166, 175, 184, 175, 185, 178,
+ 179, 178, 180, 178, 192, 190, 186, 194, 204, 76,
+ 69, 204, 202, 215, 210, 202, 218, 215, 220, 226,
- 366, 203, 214, 204, 218, 202, 220, 212, 207, 223,
- 218, 212, 239, 245, 366, 232, 233, 246, 241, 248,
- 251, 241, 241, 252, 258, 251, 247, 248, 251, 256,
- 366, 366, 251, 366, 257, 269, 269, 278, 270, 279,
- 283, 279, 283, 291, 279, 286, 294, 366, 295, 292,
- 366, 366, 287, 296, 366, 301, 294, 302, 366, 293,
- 305, 323, 318, 366, 326, 318, 328, 322, 366, 366,
- 366
+ 218, 384, 223, 236, 227, 241, 225, 243, 236, 230,
+ 246, 242, 237, 253, 258, 384, 245, 249, 263, 259,
+ 266, 270, 260, 261, 274, 281, 274, 270, 271, 275,
+ 279, 384, 384, 274, 384, 281, 294, 283, 291, 283,
+ 295, 300, 297, 301, 310, 298, 306, 316, 384, 318,
+ 315, 384, 384, 310, 319, 384, 325, 317, 325, 384,
+ 317, 330, 337, 331, 384, 339, 334, 345, 340, 384,
+ 384, 384
-static const flex_int16_t yy_def[172] =
+static const flex_int16_t yy_def[173] =
{ 0,
- 171, 1, 171, 171, 171, 171, 171, 171, 171, 171,
- 171, 171, 171, 171, 171, 171, 171, 171, 171, 171,
+ 172, 1, 172, 172, 172, 172, 172, 172, 172, 172,
+ 172, 172, 172, 172, 172, 172, 172, 172, 172, 172,
+ 172, 172, 172, 172, 12, 172, 172, 172, 172, 172,
- 0
+ 172, 0
-static const flex_int16_t yy_nxt[419] =
+static const flex_int16_t yy_nxt[437] =
{ 0,
4, 5, 6, 7, 8, 4, 9, 10, 11, 12,
13, 4, 4, 14, 4, 15, 4, 16, 4, 4,
@@ -741,50 +741,52 @@
17, 18, 4, 4, 19, 4, 20, 21, 4, 4,
4, 22, 4, 14, 4, 15, 4, 16, 4, 4,
- 4, 22, 23, 23, 23, 23, 24, 25, 27, 25,
- 29, 32, 33, 34, 30, 28, 35, 36, 37, 31,
- 38, 40, 23, 23, 90, 41, 39, 41, 43, 42,
- 38, 40, 27, 25, 26, 44, 39, 45, 43, 28,
+ 4, 22, 23, 23, 23, 23, 24, 25, 27, 27,
+ 30, 27, 33, 27, 31, 28, 25, 34, 35, 32,
+ 36, 37, 29, 38, 41, 39, 23, 23, 91, 44,
+ 30, 40, 33, 45, 31, 91, 46, 34, 35, 32,
+ 36, 37, 29, 38, 41, 39, 77, 27, 27, 44,
- 28, 46, 47, 48, 49, 50, 51, 52, 53, 54,
- 55, 56, 57, 58, 59, 44, 60, 45, 61, 28,
- 55, 56, 57, 58, 59, 62, 60, 63, 61, 64,
- 65, 66, 67, 68, 69, 70, 71, 72, 73, 74,
- 75, 77, 78, 79, 80, 62, 81, 63, 82, 64,
- 75, 77, 78, 79, 80, 87, 81, 88, 82, 83,
- 89, 91, 90, 92, 93, 94, 84, 95, 96, 97,
- 85, 98, 86, 99, 100, 87, 101, 88, 102, 83,
+ 27, 40, 27, 45, 47, 26, 46, 27, 27, 48,
+ 27, 29, 27, 49, 42, 26, 42, 50, 43, 51,
+ 52, 53, 54, 55, 47, 56, 57, 27, 27, 48,
+ 27, 29, 27, 49, 58, 43, 59, 50, 60, 51,
+ 52, 53, 54, 55, 61, 56, 57, 62, 63, 64,
+ 65, 66, 67, 68, 58, 69, 59, 70, 60, 71,
+ 72, 73, 74, 78, 61, 75, 76, 62, 63, 64,
+ 65, 66, 67, 68, 79, 69, 80, 70, 81, 71,
+ 72, 73, 74, 78, 82, 75, 76, 83, 43, 88,
+ 89, 90, 92, 91, 79, 26, 80, 93, 81, 26,
- 103, 91, 104, 92, 93, 94, 84, 95, 96, 97,
- 85, 98, 86, 99, 100, 105, 101, 106, 102, 107,
- 103, 108, 104, 109, 110, 111, 112, 113, 114, 115,
- 116, 117, 118, 119, 120, 105, 121, 106, 122, 107,
- 123, 108, 124, 109, 110, 111, 112, 113, 114, 115,
- 116, 117, 118, 119, 120, 125, 121, 126, 122, 127,
- 123, 128, 124, 129, 130, 131, 132, 133, 134, 135,
- 136, 137, 138, 139, 140, 125, 141, 126, 142, 127,
- 143, 128, 144, 129, 130, 131, 132, 133, 134, 135,
- 136, 137, 138, 139, 140, 145, 141, 146, 142, 147,
+ 94, 172, 95, 96, 82, 97, 98, 83, 84, 88,
+ 89, 99, 92, 100, 101, 85, 102, 93, 103, 86,
+ 94, 87, 95, 96, 104, 97, 98, 105, 84, 106,
+ 107, 99, 108, 100, 101, 85, 102, 109, 103, 86,
+ 110, 87, 111, 114, 104, 112, 113, 105, 115, 106,
+ 107, 116, 108, 117, 118, 119, 120, 109, 121, 122,
+ 110, 123, 111, 114, 124, 112, 113, 125, 115, 126,
+ 127, 116, 128, 117, 118, 119, 120, 129, 121, 122,
+ 130, 123, 131, 132, 124, 133, 134, 125, 135, 126,
+ 127, 136, 128, 137, 138, 139, 140, 129, 141, 142,
- 143, 148, 144, 149, 150, 151, 152, 153, 154, 155,
- 156, 157, 158, 159, 160, 145, 161, 146, 162, 147,
- 163, 148, 164, 149, 150, 151, 152, 153, 154, 155,
- 156, 157, 158, 159, 160, 165, 161, 166, 162, 167,
- 163, 168, 164, 169, 170, 90, 76, 42, 42, 26,
- 26, 26, 171, 171, 171, 165, 171, 166, 171, 167,
- 171, 168, 171, 169, 170, 3, 171, 171, 171, 171,
+ 130, 143, 131, 132, 144, 133, 134, 145, 135, 146,
+ 147, 136, 148, 137, 138, 139, 140, 149, 141, 142,
+ 150, 143, 151, 152, 144, 153, 154, 145, 155, 146,
+ 147, 156, 148, 157, 158, 159, 160, 149, 161, 162,
+ 150, 163, 151, 152, 164, 153, 154, 165, 155, 166,
+ 167, 156, 168, 157, 158, 159, 160, 169, 161, 162,
+ 170, 163, 171, 172, 164, 172, 172, 165, 172, 166,
+ 167, 172, 168, 172, 172, 172, 172, 169, 172, 172,
+ 170, 172, 171, 3, 172, 172, 172, 172, 172, 172,
-static const flex_int16_t yy_chk[419] =
+static const flex_int16_t yy_chk[437] =
{ 0,
1, 1, 1, 1, 1, 1, 1, 1, 1, 1,
@@ -792,46 +794,48 @@
1, 1, 5, 5, 6, 6, 10, 10, 12, 12,
- 14, 15, 16, 17, 14, 12, 18, 19, 20, 14,
- 21, 22, 23, 23, 90, 28, 21, 28, 29, 28,
- 21, 22, 25, 25, 26, 30, 21, 31, 29, 25,
+ 14, 12, 15, 12, 14, 12, 12, 16, 17, 14,
+ 18, 19, 12, 20, 22, 21, 23, 23, 91, 30,
+ 14, 21, 15, 31, 14, 90, 32, 16, 17, 14,
+ 18, 19, 12, 20, 22, 21, 65, 26, 26, 30,
- 26, 32, 33, 34, 35, 36, 36, 37, 38, 39,
- 43, 44, 45, 46, 47, 30, 48, 31, 49, 25,
- 43, 44, 45, 46, 47, 50, 48, 51, 49, 52,
- 54, 55, 56, 57, 58, 59, 60, 61, 62, 63,
- 63, 65, 66, 67, 68, 50, 70, 51, 71, 52,
- 63, 65, 66, 67, 68, 74, 70, 75, 71, 72,
- 76, 77, 76, 78, 79, 80, 72, 81, 82, 83,
- 72, 84, 72, 85, 86, 74, 87, 75, 88, 72,
+ 26, 21, 26, 31, 33, 26, 32, 28, 28, 34,
+ 28, 26, 28, 35, 29, 28, 29, 36, 29, 37,
+ 37, 38, 39, 40, 33, 44, 45, 43, 43, 34,
+ 43, 26, 43, 35, 46, 43, 47, 36, 48, 37,
+ 37, 38, 39, 40, 49, 44, 45, 50, 51, 52,
+ 53, 55, 56, 57, 46, 58, 47, 59, 48, 60,
+ 61, 62, 63, 66, 49, 64, 64, 50, 51, 52,
+ 53, 55, 56, 57, 67, 58, 68, 59, 69, 60,
+ 61, 62, 63, 66, 71, 64, 64, 72, 42, 75,
+ 76, 77, 78, 77, 67, 24, 68, 79, 69, 11,
- 91, 77, 92, 78, 79, 80, 72, 81, 82, 83,
- 72, 84, 72, 85, 86, 93, 87, 94, 88, 95,
- 91, 96, 92, 97, 98, 99, 99, 100, 102, 103,
- 104, 105, 106, 107, 108, 93, 109, 94, 110, 95,
- 111, 96, 112, 97, 98, 99, 99, 100, 102, 103,
- 104, 105, 106, 107, 108, 113, 109, 114, 110, 116,
- 111, 117, 112, 118, 119, 120, 121, 122, 123, 124,
- 125, 126, 127, 128, 129, 113, 130, 114, 133, 116,
- 135, 117, 136, 118, 119, 120, 121, 122, 123, 124,
- 125, 126, 127, 128, 129, 137, 130, 138, 133, 139,
+ 80, 3, 81, 82, 71, 83, 84, 72, 73, 75,
+ 76, 85, 78, 86, 87, 73, 88, 79, 89, 73,
+ 80, 73, 81, 82, 92, 83, 84, 93, 73, 94,
+ 95, 85, 96, 86, 87, 73, 88, 97, 89, 73,
+ 98, 73, 99, 101, 92, 100, 100, 93, 103, 94,
+ 95, 104, 96, 105, 106, 107, 108, 97, 109, 110,
+ 98, 111, 99, 101, 112, 100, 100, 113, 103, 114,
+ 115, 104, 117, 105, 106, 107, 108, 118, 109, 110,
+ 119, 111, 120, 121, 112, 122, 123, 113, 124, 114,
+ 115, 125, 117, 126, 127, 128, 129, 118, 130, 131,
- 135, 140, 136, 141, 142, 143, 144, 145, 146, 147,
- 149, 150, 153, 154, 156, 137, 157, 138, 158, 139,
- 160, 140, 161, 141, 142, 143, 144, 145, 146, 147,
- 149, 150, 153, 154, 156, 162, 157, 163, 158, 165,
- 160, 166, 161, 167, 168, 89, 64, 42, 41, 27,
- 24, 11, 3, 0, 0, 162, 0, 163, 0, 165,
- 0, 166, 0, 167, 168, 171, 171, 171, 171, 171,
+ 119, 134, 120, 121, 136, 122, 123, 137, 124, 138,
+ 139, 125, 140, 126, 127, 128, 129, 141, 130, 131,
+ 142, 134, 143, 144, 136, 145, 146, 137, 147, 138,
+ 139, 148, 140, 150, 151, 154, 155, 141, 157, 158,
+ 142, 159, 143, 144, 161, 145, 146, 162, 147, 163,
+ 164, 148, 166, 150, 151, 154, 155, 167, 157, 158,
+ 168, 159, 169, 0, 161, 0, 0, 162, 0, 163,
+ 164, 0, 166, 0, 0, 0, 0, 167, 0, 0,
+ 168, 0, 169, 172, 172, 172, 172, 172, 172, 172,
static yy_state_type yy_last_accepting_state;
@@ -886,10 +890,10 @@
} while (0);
-#line 889 "lwin_wkt_lex.c"
+#line 893 "lwin_wkt_lex.c"
#define YY_NO_INPUT 1
/* Suppress the default implementations. */
-#line 892 "lwin_wkt_lex.c"
+#line 896 "lwin_wkt_lex.c"
#define INITIAL 0
@@ -1107,7 +1111,7 @@
#line 49 "lwin_wkt_lex.l"
-#line 1110 "lwin_wkt_lex.c"
+#line 1114 "lwin_wkt_lex.c"
while ( /*CONSTCOND*/1 ) /* loops until end-of-file is reached */
@@ -1134,13 +1138,13 @@
while ( yy_chk[yy_base[yy_current_state] + yy_c] != yy_current_state )
yy_current_state = (int) yy_def[yy_current_state];
- if ( yy_current_state >= 172 )
+ if ( yy_current_state >= 173 )
yy_c = yy_meta[yy_c];
yy_current_state = yy_nxt[yy_base[yy_current_state] + yy_c];
++yy_cp;
- while ( yy_current_state != 171 );
+ while ( yy_current_state != 172 );
yy_cp = (yy_last_accepting_cpos);
yy_current_state = (yy_last_accepting_state);
@@ -1161,17 +1165,19 @@
goto yy_find_action;
case 1:
+/* rule 1 can match eol */
YY_RULE_SETUP
#line 51 "lwin_wkt_lex.l"
LWDEBUG(5,"DOUBLE");
- wkt_yylval.doublevalue = atof(wkt_yytext);
+ wkt_yylval.doublevalue = atof(wkt_yytext);
+ yyless(wkt_yyleng-1);
return DOUBLE_TOK;
YY_BREAK
case 2:
YY_RULE_SETUP
-#line 57 "lwin_wkt_lex.l"
+#line 58 "lwin_wkt_lex.l"
LWDEBUG(5,"SRID");
wkt_yylval.integervalue = wkt_lexer_read_srid(wkt_yytext);
@@ -1180,87 +1186,87 @@
YY_BREAK
case 3:
YY_RULE_SETUP
-#line 63 "lwin_wkt_lex.l"
+#line 64 "lwin_wkt_lex.l"
{ return COLLECTION_TOK; }
YY_BREAK
case 4:
YY_RULE_SETUP
-#line 64 "lwin_wkt_lex.l"
+#line 65 "lwin_wkt_lex.l"
{ return MSURFACE_TOK; }
YY_BREAK
case 5:
YY_RULE_SETUP
-#line 65 "lwin_wkt_lex.l"
+#line 66 "lwin_wkt_lex.l"
{ return MPOLYGON_TOK; }
YY_BREAK
case 6:
YY_RULE_SETUP
-#line 66 "lwin_wkt_lex.l"
+#line 67 "lwin_wkt_lex.l"
{ return MCURVE_TOK; }
YY_BREAK
case 7:
YY_RULE_SETUP
-#line 67 "lwin_wkt_lex.l"
+#line 68 "lwin_wkt_lex.l"
{ return MLINESTRING_TOK; }
YY_BREAK
case 8:
YY_RULE_SETUP
-#line 68 "lwin_wkt_lex.l"
+#line 69 "lwin_wkt_lex.l"
{ return MPOINT_TOK; }
YY_BREAK
case 9:
YY_RULE_SETUP
-#line 69 "lwin_wkt_lex.l"
+#line 70 "lwin_wkt_lex.l"
{ return CURVEPOLYGON_TOK; }
YY_BREAK
case 10:
YY_RULE_SETUP
-#line 70 "lwin_wkt_lex.l"
+#line 71 "lwin_wkt_lex.l"
{ return POLYGON_TOK; }
YY_BREAK
case 11:
YY_RULE_SETUP
-#line 71 "lwin_wkt_lex.l"
+#line 72 "lwin_wkt_lex.l"
{ return COMPOUNDCURVE_TOK; }
YY_BREAK
case 12:
YY_RULE_SETUP
-#line 72 "lwin_wkt_lex.l"
+#line 73 "lwin_wkt_lex.l"
{ return CIRCULARSTRING_TOK; }
YY_BREAK
case 13:
YY_RULE_SETUP
-#line 73 "lwin_wkt_lex.l"
+#line 74 "lwin_wkt_lex.l"
{ return LINESTRING_TOK; }
YY_BREAK
case 14:
YY_RULE_SETUP
-#line 74 "lwin_wkt_lex.l"
+#line 75 "lwin_wkt_lex.l"
{ return POLYHEDRALSURFACE_TOK; }
YY_BREAK
case 15:
YY_RULE_SETUP
-#line 75 "lwin_wkt_lex.l"
+#line 76 "lwin_wkt_lex.l"
{ return TRIANGLE_TOK; }
YY_BREAK
case 16:
YY_RULE_SETUP
-#line 76 "lwin_wkt_lex.l"
+#line 77 "lwin_wkt_lex.l"
{ return TIN_TOK; }
YY_BREAK
case 17:
YY_RULE_SETUP
-#line 77 "lwin_wkt_lex.l"
+#line 78 "lwin_wkt_lex.l"
{ return POINT_TOK; }
YY_BREAK
case 18:
YY_RULE_SETUP
-#line 78 "lwin_wkt_lex.l"
+#line 79 "lwin_wkt_lex.l"
{ return EMPTY_TOK; }
YY_BREAK
case 19:
YY_RULE_SETUP
-#line 80 "lwin_wkt_lex.l"
+#line 81 "lwin_wkt_lex.l"
LWDEBUG(5,"DIMENSIONALITY");
wkt_yylval.stringvalue = wkt_yytext;
@@ -1269,33 +1275,33 @@
YY_BREAK
case 20:
YY_RULE_SETUP
-#line 86 "lwin_wkt_lex.l"
+#line 87 "lwin_wkt_lex.l"
{ LWDEBUG(5,"LBRACKET"); return LBRACKET_TOK; }
YY_BREAK
case 21:
YY_RULE_SETUP
-#line 87 "lwin_wkt_lex.l"
+#line 88 "lwin_wkt_lex.l"
{ LWDEBUG(5,"RBRACKET"); return RBRACKET_TOK; }
YY_BREAK
case 22:
YY_RULE_SETUP
-#line 88 "lwin_wkt_lex.l"
+#line 89 "lwin_wkt_lex.l"
{ LWDEBUG(5,"COMMA"); return COMMA_TOK; }
YY_BREAK
case 23:
YY_RULE_SETUP
-#line 89 "lwin_wkt_lex.l"
+#line 90 "lwin_wkt_lex.l"
{ LWDEBUG(5,"SEMICOLON"); return SEMICOLON_TOK; }
YY_BREAK
case 24:
/* rule 24 can match eol */
YY_RULE_SETUP
-#line 91 "lwin_wkt_lex.l"
+#line 92 "lwin_wkt_lex.l"
{ /* ignore whitespace */ LWDEBUG(5,"WHITESPACE"); }
YY_BREAK
case 25:
YY_RULE_SETUP
-#line 93 "lwin_wkt_lex.l"
+#line 94 "lwin_wkt_lex.l"
{ /* Error out and stop parsing on unknown/unexpected characters */
LWDEBUG(5,"UNKNOWN");
wkt_lexer_unknown();
@@ -1304,10 +1310,10 @@
YY_BREAK
case 26:
YY_RULE_SETUP
-#line 99 "lwin_wkt_lex.l"
+#line 100 "lwin_wkt_lex.l"
ECHO;
YY_BREAK
-#line 1310 "lwin_wkt_lex.c"
+#line 1316 "lwin_wkt_lex.c"
case YY_STATE_EOF(INITIAL):
yyterminate();
@@ -1605,7 +1611,7 @@
@@ -1633,11 +1639,11 @@
- yy_is_jam = (yy_current_state == 171);
+ yy_is_jam = (yy_current_state == 172);
return yy_is_jam ? 0 : yy_current_state;
@@ -2253,7 +2259,7 @@
#define YYTABLES_NAME "yytables"
void *wkt_yyalloc (yy_size_t size )
Modified: trunk/liblwgeom/lwin_wkt_lex.l
--- trunk/liblwgeom/lwin_wkt_lex.l 2018-07-23 00:17:50 UTC (rev 16661)
+++ trunk/liblwgeom/lwin_wkt_lex.l 2018-07-23 15:42:59 UTC (rev 16662)
@@ -48,9 +48,10 @@
--?(([0-9]+\.?)|([0-9]*\.?[0-9]+)([eE][-+]?[0-9]+)?) {
+-?(([0-9]+\.?)|([0-9]*\.?[0-9]+)([eE][-+]?[0-9]+)?)[ \,\)\t\n\r] {
return DOUBLE_TOK;
