[postgis-tickets] [PostGIS] #4081: ST_DWithin using spheroid does not calculate distance properly for geography
trac at osgeo.org
Tue Jul 24 10:24:10 PDT 2018
geography
Reporter: amc6 | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.4.5
Component: postgis | Version: 2.4.x
Resolution: | Keywords:
Comment (by pramsey):
Aha, it's not the distance calculation, it's the index call, so all the
uncached calls work fine, since they avoid the SQL index wrapper, but the
calls to ST_DWithin include the index optimization, which is returning the
wrong answer:
select
a && _ST_Expand(b,111155.5) as index_b_11155_5,
b && _ST_Expand(a,111155.5) as index_a_11155_5,
a && _ST_Expand(b,111155.6) as index_b_11155_6,
b && _ST_Expand(a,111155.6) as index_a_11155_6
from (
select ST_GeogFromText('SRID=4326;POINT(1.0 2.0)') as a,
ST_GeogFromText('SRID=4326;POINT(1.0 1.0)') as b
) as points
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4081#comment:3>
