[postgis-tickets] [PostGIS] #4134: MVT test failure in trunk
trac at osgeo.org
Thu Jul 26 00:22:02 PDT 2018
Reporter: dbaston | Owner: Algunenano
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.5.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Changes (by Algunenano):
* owner: pramsey => Algunenano
* status: assigned => new
Comment:
I'll add that ST_AsMVTGeom was ok with invalid geometries, either as input
or after some of its internal transformations. Part of that was
`lwgeom_clip_by_rect` being ok with them too. And, at least for 2.5, we
want to keep this behaviour. I'll do some performance tests of the
possible solutions.
> This should make MVT clipping work as it did in 2.4. I verified that it
works locally but it requires rewriting the MVT tests to use ST_Equals
instead of text comparison.
I'm avoiding St_Equals as it ignores directionality, which is mandatory in
the MVT spec 2.1, and we have already been bitten by it (the tests used to
ignore it, so introducing bugs was pretty easy).
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4134#comment:1>
