[postgis-tickets] [PostGIS] #4118: Memory sanitizer warnings
trac at osgeo.org
Fri Jul 27 04:56:02 PDT 2018
Reporter: Algunenano | Owner: Algunenano
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.5.0
Component: postgis | Version: trunk
Resolution: fixed | Keywords:
Changes (by Algunenano):
* status: assigned => closed
* resolution: => fixed
Comment:
The only pending warnings are related to json-c (cu_in_geojson.c) and one
that looks like an issue in GEOS:
Suite: geometry_clean
Test: test_lwgeom_make_valid ...Uninitialized bytes in
__interceptor_memcmp at offset 0 inside [0x7ffe9a5bc230, 256)
==11015==WARNING: MemorySanitizer: use-of-uninitialized-value
#0 0x7f3e496ef4cc in std::ctype<char>::_M_widen_init() const
/build/gcc/src/gcc/libstdc++-v3/src/c++11/ctype.cc:98:25
#1 0x7f3e4974d208 in std::ctype<char>::widen(char) const
/build/gcc/src/gcc-build/x86_64-pc-linux-
gnu/libstdc++-v3/include/bits/locale_facets.h:876:21
#2 0x7f3e4974d208 in std::basic_ios<char, std::char_traits<char>
>::widen(char) const /build/gcc/src/gcc-build/x86_64-pc-linux-
gnu/libstdc++-v3/include/bits/basic_ios.h:450:49
#3 0x7f3e4974d208 in std::basic_ios<char, std::char_traits<char>
>::fill() const /build/gcc/src/gcc-build/x86_64-pc-linux-
gnu/libstdc++-v3/include/bits/basic_ios.h:374:14
#4 0x7f3e4974d208 in std::ostream&
std::ostream::_M_insert<double>(double) /build/gcc/src/gcc-build/x86_64
-pc-linux-gnu/libstdc++-v3/include/bits/ostream.tcc:73:49
#5 0x7f3e49bf215c in geos::geom::operator<<(std::ostream&,
geos::geom::Coordinate const&) /home/raul/dev/PKGBUILDs/geos-
git/src/geos/src/geom/Coordinate.cpp:51:6
#6 0x7f3e49bf2086 in geos::geom::Coordinate::toString[abi:cxx11]()
const /home/raul/dev/PKGBUILDs/geos-
git/src/geos/src/geom/Coordinate.cpp:43:29
#7 0x7f3e49d1a679 in
geos::operation::valid::TopologyValidationError::toString[abi:cxx11]()
git/src/geos/src/operation/valid/TopologyValidationError.cpp:83:61
#8 0x7f3e4b66b858 in GEOSisValid_r /home/raul/dev/PKGBUILDs/geos-
git/src/geos/capi/geos_ts_c.cpp:939:46
#9 0x7f3e4b66622f in GEOSisValid /home/raul/dev/PKGBUILDs/geos-
git/src/geos/capi/geos_c.cpp:242:12
#10 0x7f3e4bb2821a in LWGEOM_GEOS_makeValid
/home/raul/dev/public/postgis/liblwgeom/lwgeom_geos_clean.c:711:13
#11 0x7f3e4bb2b53e in lwgeom_make_valid
/home/raul/dev/public/postgis/liblwgeom/lwgeom_geos_clean.c:888:12
#12 0x556972fae6b4 in test_lwgeom_make_valid
/home/raul/dev/public/postgis/liblwgeom/cunit/cu_clean.c:55:9
#13 0x7f3e4b437117 (/usr/lib/libcunit.so.1+0x4117)
#14 0x7f3e4b4373b1 (/usr/lib/libcunit.so.1+0x43b1)
#15 0x7f3e4b4377b6 in CU_run_all_tests (/usr/lib/libcunit.so.1+0x47b6)
#16 0x556973060757 in main
/home/raul/dev/public/postgis/liblwgeom/cunit/cu_tester.c:177:13
#17 0x7f3e4a4c306a in __libc_start_main (/usr/lib/libc.so.6+0x2306a)
#18 0x556972f24db9 in _start
(/home/raul/dev/public/postgis/liblwgeom/cunit/.libs/lt-cu_tester+0x24db9)
Uninitialized value was created by an allocation of 'yyvsa' in the stack
frame of function 'wkt_yyparse'
#0 0x7f3e4b9c7580 in wkt_yyparse
/home/raul/dev/public/postgis/liblwgeom/lwin_wkt_parse.c:1634
SUMMARY: MemorySanitizer: use-of-uninitialized-value
/build/gcc/src/gcc/libstdc++-v3/src/c++11/ctype.cc:98:25 in
I'm closing this for now. At some point in the future I'll try to look
into these and report them upstream.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4118#comment:2>
