[postgis-tickets] r16676 - Make lwgeom_subdivide use lwgeom_intersection for clipping
Daniel Baston
dbaston at gmail.com
Tue Jul 31 05:45:02 PDT 2018
Author: dbaston
Date: 2018-07-31 17:45:01 -0700 (Tue, 31 Jul 2018)
New Revision: 16676
trunk/liblwgeom/lwgeom.c
lwgeom_clip_by_rect describes itself as clipping in a "fast but possibly
dirty way." This is not a good fit for lwgeom_subdivide, a primary use of
which is the optimization of point-in-polygon processes. That application
requires that the area covered by the subdivided geometry be the same as
the area covered by the original geometry, which in turn requires that a
robust intersection routine be used.
References #4038
Closes https://github.com/postgis/postgis/pull/281
Modified: trunk/liblwgeom/lwgeom.c
--- trunk/liblwgeom/lwgeom.c 2018-07-30 16:38:45 UTC (rev 16675)
+++ trunk/liblwgeom/lwgeom.c 2018-08-01 00:45:01 UTC (rev 16676)
@@ -2249,10 +2249,10 @@
/* Prototype for recursion */
-static int lwgeom_subdivide_recursive(const LWGEOM *geom, uint32_t maxvertices, uint32_t depth, LWCOLLECTION *col);
+static int lwgeom_subdivide_recursive(const LWGEOM *geom, uint8_t dimension, uint32_t maxvertices, uint32_t depth, LWCOLLECTION *col);
static int
-lwgeom_subdivide_recursive(const LWGEOM *geom, uint32_t maxvertices, uint32_t depth, LWCOLLECTION *col)
+lwgeom_subdivide_recursive(const LWGEOM *geom, uint8_t dimension, uint32_t maxvertices, uint32_t depth, LWCOLLECTION *col)
const uint32_t maxdepth = 50;
GBOX clip, subbox1, subbox2;
@@ -2275,7 +2275,7 @@
if ( width == 0.0 && height == 0.0 )
- if ( geom->type == POINTTYPE )
+ if ( geom->type == POINTTYPE && dimension == 0)
lwcollection_add_lwgeom(col, lwgeom_clone_deep(geom));
return 1;
@@ -2303,12 +2303,19 @@
LWCOLLECTION *incol = (LWCOLLECTION*)geom;
int n = 0;
/* Don't increment depth yet, since we aren't actually
- * subdividing geomtries yet */
+ * subdividing geometries yet */
for ( i = 0; i < incol->ngeoms; i++ )
- n += lwgeom_subdivide_recursive(incol->geoms[i], maxvertices, depth, col);
+ n += lwgeom_subdivide_recursive(incol->geoms[i], dimension, maxvertices, depth, col);
return n;
+ if (lwgeom_dimension(geom) < dimension)
+ /* We've hit a lower dimension object produced by clipping at
+ * a shallower recursion level. Ignore it. */
+ return 0;
/* But don't go too far. 2^50 ~= 10^15, that's enough subdivision */
/* Just add what's left */
if ( depth > maxdepth )
@@ -2391,17 +2398,23 @@
++depth;
- clipped = lwgeom_clip_by_rect(geom, subbox1.xmin, subbox1.ymin, subbox1.xmax, subbox1.ymax);
+ LWGEOM* subbox = (LWGEOM*) lwpoly_construct_envelope(geom->srid, subbox1.xmin, subbox1.ymin, subbox1.xmax, subbox1.ymax);
+ clipped = lwgeom_intersection(geom, subbox);
+ lwgeom_simplify_in_place(clipped, 0.0, LW_TRUE);
+ lwgeom_free(subbox);
if (clipped)
- n += lwgeom_subdivide_recursive(clipped, maxvertices, depth, col);
+ n += lwgeom_subdivide_recursive(clipped, dimension, maxvertices, depth, col);
lwgeom_free(clipped);
- clipped = lwgeom_clip_by_rect(geom, subbox2.xmin, subbox2.ymin, subbox2.xmax, subbox2.ymax);
+ subbox = (LWGEOM*) lwpoly_construct_envelope(geom->srid, subbox2.xmin, subbox2.ymin, subbox2.xmax, subbox2.ymax);
if (clipped)
@@ -2426,7 +2439,7 @@
lwerror("%s: cannot subdivide to fewer than %d vertices per output", __func__, minmaxvertices);
- lwgeom_subdivide_recursive(geom, maxvertices, startdepth, col);
+ lwgeom_subdivide_recursive(geom, lwgeom_dimension(geom), maxvertices, startdepth, col);
lwgeom_set_srid((LWGEOM*)col, geom->srid);
return col;
