[postgis-tickets] r16555 - Replace GEOSPreparedContains with internal winding number algorithm
bjorn at wololo.org
bjorn at wololo.org
Sun May 6 09:34:55 PDT 2018
Author: bjornharrtell
Date: 2018-05-06 09:34:55 -0700 (Sun, 06 May 2018)
New Revision: 16555
trunk/NEWS
trunk/liblwgeom/lwgeom_topo.c
trunk/topology/test/perf/TopoGeo_addLinestring.sql
References #4076
Modified: trunk/NEWS
--- trunk/NEWS 2018-04-24 14:39:39 UTC (rev 16554)
+++ trunk/NEWS 2018-05-06 16:34:55 UTC (rev 16555)
@@ -60,8 +60,8 @@
- #4025, #4032 Fixed precision issue in ST_ClosestPointOfApproach,
ST_DistanceCPA, and ST_CPAWithin (Paul Ramsey, Darafei Praliaskouski)
- #4071, ST_ClusterKMeans crash on NULL/EMPTY fixed (Darafei Praliaskouski)
+ - #4076, Reduce use of GEOS in topology implementation (Björn Harrtell)
PostGIS 2.4.0
2017/09/30
Modified: trunk/liblwgeom/lwgeom_topo.c
--- trunk/liblwgeom/lwgeom_topo.c 2018-04-24 14:39:39 UTC (rev 16554)
+++ trunk/liblwgeom/lwgeom_topo.c 2018-05-06 16:34:55 UTC (rev 16555)
@@ -607,7 +607,6 @@
LWT_ISO_NODE *nodes;
const GBOX *edgebox;
GEOSGeometry *edgegg;
- const GEOSPreparedGeometry* prepared_edge;
initGEOS(lwnotice, lwgeom_geos_error);
@@ -616,11 +615,6 @@
lwerror("Could not convert edge geometry to GEOS: %s", lwgeom_geos_errmsg);
return -1;
- prepared_edge = GEOSPrepare( edgegg );
- if ( ! prepared_edge ) {
- lwerror("Could not prepare edge geometry: %s", lwgeom_geos_errmsg);
- return -1;
edgebox = lwgeom_get_bbox( lwline_as_lwgeom(geom) );
/* loop over each node within the edge's gbox */
@@ -628,8 +622,6 @@
LWT_COL_NODE_ALL, 0 );
LWDEBUGF(1, "lwt_be_getNodeWithinBox2D returned %d nodes", num_nodes);
if ( num_nodes == -1 ) {
- GEOSPreparedGeom_destroy(prepared_edge);
- GEOSGeom_destroy(edgegg);
lwerror("Backend error: %s", lwt_be_lastErrorMessage(topo->be_iface));
return -1;
@@ -636,26 +628,14 @@
for ( i=0; i<num_nodes; ++i )
LWT_ISO_NODE* node = &(nodes[i]);
- GEOSGeometry *nodegg;
- int contains;
if ( node->node_id == start_node ) continue;
if ( node->node_id == end_node ) continue;
/* check if the edge contains this node (not on boundary) */
- nodegg = LWGEOM2GEOS( lwpoint_as_lwgeom(node->geom) , 0);
/* ST_RelateMatch(rec.relate, 'T********') */
- contains = GEOSPreparedContains( prepared_edge, nodegg );
- GEOSGeom_destroy(nodegg);
- if (contains == 2)
- _lwt_release_nodes(nodes, num_nodes);
- lwerror("GEOS exception on PreparedContains: %s", lwgeom_geos_errmsg);
- return -1;
+ const POINT2D *pt = getPoint2d_cp(node->geom->point, 0);
+ int contains = ptarray_contains_point_partial(geom->points, pt, LW_FALSE, NULL) == LW_BOUNDARY;
if ( contains )
lwerror("SQL/MM Spatial exception - geometry crosses a node");
@@ -669,7 +649,6 @@
edges = lwt_be_getEdgeWithinBox2D( topo, edgebox, &num_edges, LWT_COL_EDGE_ALL, 0 );
LWDEBUGF(1, "lwt_be_getEdgeWithinBox2D returned %d edges", num_edges);
if ( num_edges == -1 ) {
return -1;
@@ -692,7 +671,6 @@
eegg = LWGEOM2GEOS( lwline_as_lwgeom(edge->geom), 0 );
if ( ! eegg ) {
_lwt_release_edges(edges, num_edges);
@@ -706,7 +684,6 @@
relate = GEOSRelateBoundaryNodeRule(eegg, edgegg, 2);
if ( ! relate ) {
GEOSGeom_destroy(eegg);
lwerror("GEOSRelateBoundaryNodeRule error: %s", lwgeom_geos_errmsg);
@@ -722,7 +699,6 @@
GEOSFree(relate);
if ( match == 2 ) {
lwerror("GEOSRelatePatternMatch error: %s", lwgeom_geos_errmsg);
return -1;
@@ -733,7 +709,6 @@
match = GEOSRelatePatternMatch(relate, "1FFF*FFF2");
if ( match ) {
GEOSFree(relate);
@@ -749,7 +724,6 @@
match = GEOSRelatePatternMatch(relate, "1********");
if ( match ) {
GEOSFree(relate);
@@ -765,7 +739,6 @@
match = GEOSRelatePatternMatch(relate, "T********");
if ( match ) {
GEOSFree(relate);
@@ -786,7 +759,6 @@
if ( edges ) _lwt_release_edges(edges, num_edges);
/* would be NULL if num_edges was 0 */
return 0;
@@ -2055,25 +2027,6 @@
return -2;
LWDEBUGF(1, "lwt_be_getEdgeByFace returned %d edges", numfaceedges);
- GEOSGeometry *shellgg = 0;
- const GEOSPreparedGeometry* prepshell = 0;
- shellgg = LWGEOM2GEOS( lwpoly_as_lwgeom(shell), 0);
- if ( ! shellgg ) {
- lwpoly_free(shell);
- lwfree(signed_edge_ids);
- _lwt_release_edges(edges, numfaceedges);
- lwerror("Could not convert shell geometry to GEOS: %s", lwgeom_geos_errmsg);
- return -2;
- prepshell = GEOSPrepare( shellgg );
- if ( ! prepshell ) {
- GEOSGeom_destroy(shellgg);
- lwerror("Could not prepare shell geometry: %s", lwgeom_geos_errmsg);
- return -2;
if ( numfaceedges )
@@ -2088,8 +2041,6 @@
LWT_ISO_EDGE *e = &(edges[i]);
int found = 0;
int contains;
- GEOSGeometry *egg;
- LWPOINT *epgeom;
POINT2D ep;
/* (2.1) skip edges whose ID is in the list of boundary edges ? */
@@ -2124,8 +2075,6 @@
if ( ! _lwt_GetInteriorEdgePoint(e->geom, &ep) )
- GEOSPreparedGeom_destroy(prepshell);
lwpoly_free(shell);
lwfree(forward_edges); /* contents owned by edges */
@@ -2136,39 +2085,10 @@
return -2;
- epgeom = lwpoint_make2d(0, ep.x, ep.y);
- egg = LWGEOM2GEOS( lwpoint_as_lwgeom(epgeom) , 0);
- lwpoint_free(epgeom);
- if ( ! egg ) {
- lwfree(forward_edges); /* contents owned by edges */
- lwfree(backward_edges); /* contents owned by edges */
- lwerror("Could not convert edge geometry to GEOS: %s",
- lwgeom_geos_errmsg);
- return -2;
- /* IDEA: can be optimized by computing this on our side rather
- * than on GEOS (saves conversion of big edges) */
/* IDEA: check that bounding box shortcut is taken, or use
* shellbox to do it here */
- contains = GEOSPreparedContains( prepshell, egg );
- GEOSGeom_destroy(egg);
+ contains = ptarray_contains_point(pa, &ep) == LW_INSIDE;
if ( contains == 2 )
- return -2;
LWDEBUGF(1, "Edge %d %scontained in new ring", e->edge_id,
(contains?"":"not "));
@@ -2274,31 +2194,8 @@
for (i=0; i<numisonodes; ++i)
LWT_ISO_NODE *n = &(nodes[i]);
- GEOSGeometry *ngg;
- ngg = LWGEOM2GEOS( lwpoint_as_lwgeom(n->geom), 0 );
- int contains;
- if ( ! ngg ) {
- _lwt_release_nodes(nodes, numisonodes);
- if ( prepshell ) GEOSPreparedGeom_destroy(prepshell);
- if ( shellgg ) GEOSGeom_destroy(shellgg);
- lwerror("Could not convert node geometry to GEOS: %s",
- return -2;
- contains = GEOSPreparedContains( prepshell, ngg );
- GEOSGeom_destroy(ngg);
- if ( contains == 2 )
- return -2;
+ const POINT2D *pt = getPoint2d_cp(n->geom->point, 0);
+ int contains = ptarray_contains_point(pa, pt) == LW_INSIDE;
LWDEBUGF(1, "Node %d is %scontained in new ring, newface is %s",
n->node_id, contains ? "" : "not ",
newface_outside ? "outside" : "inside" );
@@ -2340,8 +2237,6 @@
lwfree(updated_nodes);
lwpoly_free(shell);
@@ -3271,62 +3166,6 @@
return nseid;
-static GEOSGeometry *
-_lwt_EdgeMotionArea(LWLINE *geom, int isclosed)
- GEOSGeometry *gg;
- POINT4D p4d;
- POINTARRAY *pa;
- POINTARRAY **pas;
- LWPOLY *poly;
- LWGEOM *g;
- pas = lwalloc(sizeof(POINTARRAY*));
- initGEOS(lwnotice, lwgeom_geos_error);
- if ( isclosed )
- pas[0] = ptarray_clone_deep( geom->points );
- poly = lwpoly_construct(0, 0, 1, pas);
- gg = LWGEOM2GEOS( lwpoly_as_lwgeom(poly), 0 );
- lwpoly_free(poly); /* should also delete the pointarrays */
- else
- pa = geom->points;
- getPoint4d_p(pa, 0, &p4d);
- pas[0] = ptarray_clone_deep( pa );
- /* don't bother dup check */
- if ( LW_FAILURE == ptarray_append_point(pas[0], &p4d, LW_TRUE) )
- ptarray_free(pas[0]);
- lwfree(pas);
- lwerror("Could not append point to pointarray");
- return NULL;
- poly = lwpoly_construct(0, NULL, 1, pas);
- /* make valid, in case the edge self-intersects on its first-last
- * vertex segment */
- g = lwgeom_make_valid(lwpoly_as_lwgeom(poly));
- if ( ! g )
- lwerror("Could not make edge motion area valid");
- return NULL;
- gg = LWGEOM2GEOS(g, 0);
- lwgeom_free(g);
- if ( ! gg )
- lwerror("Could not convert old edge area geometry to GEOS: %s",
- return NULL;
- return gg;
int
lwt_ChangeEdgeGeom(LWT_TOPOLOGY* topo, LWT_ELEMID edge_id, LWLINE *geom)
@@ -3474,61 +3313,19 @@
// 3. if any node beside endnodes are found:
if ( numnodes > ( 1 + isclosed ? 0 : 1 ) )
- GEOSGeometry *oarea, *narea;
- const GEOSPreparedGeometry *oareap, *nareap;
- oarea = _lwt_EdgeMotionArea(oldedge->geom, isclosed);
- if ( ! oarea )
- _lwt_release_edges(oldedge, 1);
- lwerror("Could not compute edge motion area for old edge");
- return -1;
- narea = _lwt_EdgeMotionArea(geom, isclosed);
- if ( ! narea )
- GEOSGeom_destroy(oarea);
- lwerror("Could not compute edge motion area for new edge");
- return -1;
// 3.2. bail out if any node is in one and not the other
- oareap = GEOSPrepare( oarea );
- nareap = GEOSPrepare( narea );
for (i=0; i<numnodes; ++i)
- int ocont, ncont;
- size_t sz;
- char *wkt;
if ( n->node_id == oldedge->start_node ) continue;
if ( n->node_id == oldedge->end_node ) continue;
- ngg = LWGEOM2GEOS( lwpoint_as_lwgeom(n->geom) , 0);
- ocont = GEOSPreparedContains( oareap, ngg );
- ncont = GEOSPreparedContains( nareap, ngg );
- if (ocont == 2 || ncont == 2)
- _lwt_release_nodes(nodes, numnodes);
- GEOSPreparedGeom_destroy(oareap);
- GEOSPreparedGeom_destroy(nareap);
- GEOSGeom_destroy(narea);
- return -1;
+ int ocont = ptarray_contains_point_partial(oldedge->geom->points, pt, isclosed, NULL) == LW_INSIDE;
+ int ncont = ptarray_contains_point_partial(geom->points, pt, isclosed, NULL) == LW_INSIDE;
if (ocont != ncont)
- wkt = lwgeom_to_wkt(lwpoint_as_lwgeom(n->geom), WKT_ISO, 15, &sz);
+ size_t sz;
+ char *wkt = lwgeom_to_wkt(lwpoint_as_lwgeom(n->geom), WKT_ISO, 15, &sz);
lwerror("Edge motion collision at %s", wkt);
lwfree(wkt); /* would not necessarely reach this point */
@@ -3535,10 +3332,6 @@
return -1;
if ( numnodes ) _lwt_release_nodes(nodes, numnodes);
@@ -5222,7 +5015,6 @@
LWGEOM *g = lwline_as_lwgeom(e->geom);
LWGEOM *prj;
int contains;
- GEOSGeometry *prjg, *gg;
LWT_ELEMID edge_id = e->edge_id;
LWDEBUGF(1, "Splitting edge %" LWTFMT_ELEMID, edge_id);
@@ -5251,31 +5043,8 @@
lwgeom_free(prj);
prj = tmp;
- prjg = LWGEOM2GEOS(prj, 0);
- if ( ! prjg ) {
- lwgeom_free(prj);
- _lwt_release_edges(edges, num);
- lwerror("Could not convert edge geometry to GEOS: %s", lwgeom_geos_errmsg);
- return -1;
- if ( ! gg ) {
- lwgeom_free(prj);
- GEOSGeom_destroy(prjg);
- return -1;
- contains = GEOSContains(gg, prjg);
- GEOSGeom_destroy(gg);
- lwgeom_free(prj);
- lwerror("GEOS exception on Contains: %s", lwgeom_geos_errmsg);
- return -1;
+ const POINT2D *pt = getPoint2d_cp(lwgeom_as_lwpoint(prj)->point, 0);
+ contains = ptarray_contains_point_partial(e->geom->points, pt, 0, NULL) == LW_BOUNDARY;
if ( ! contains )
double snaptol;
Modified: trunk/topology/test/perf/TopoGeo_addLinestring.sql
--- trunk/topology/test/perf/TopoGeo_addLinestring.sql 2018-04-24 14:39:39 UTC (rev 16554)
+++ trunk/topology/test/perf/TopoGeo_addLinestring.sql 2018-05-06 16:34:55 UTC (rev 16555)
@@ -1,5 +1,5 @@
SELECT topology.CreateTopology('topoperf');
-\timing
+\timing on
SELECT count(*) FROM (
SELECT topology.TopoGeo_addLinestring('topoperf', g) FROM (
SELECT ST_ExteriorRing(ST_Buffer(ST_MakePoint(x, y), 10, 10)) g FROM
@@ -7,4 +7,5 @@
generate_series(-15,15,5) y
) foo
) bar;
+\timing off
SELECT topology.DropTopology('topoperf');
