[postgis-tickets] [PostGIS] #4078: test_gdal_configured fails with GDAL 2.3.0-rc1
trac at osgeo.org
Mon May 7 02:19:28 PDT 2018
Reporter: Bas Couwenberg | Owner: pramsey
Type: defect | Status: new
Priority: high | Milestone: PostGIS 2.4.5
Component: postgis | Version: 2.4.x
Resolution: | Keywords:
Comment (by Algunenano):
It's working for me using latest postgis with latest gdal. Either your
gdal package is missing the support files or postgis is not finding them.
Can you check if the package includes the EPSG files, like `gcs.csv`? In
my installation they are installed in `/usr/share/gdal`.
If so, can you try setting the GDAL_DATA variable before running the tests
with something like `GDAL_DATA=$(gdal-config --datadir) make check`
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4078#comment:1>
