[postgis-tickets] [PostGIS] #4078: test_gdal_configured fails with GDAL 2.3.0-rc1
trac at osgeo.org
Mon May 7 02:41:28 PDT 2018
Reporter: Bas Couwenberg | Owner: pramsey
Type: defect | Status: new
Priority: high | Milestone: PostGIS 2.4.5
Component: postgis | Version: 2.4.x
Resolution: | Keywords:
Comment (by Bas Couwenberg):
The gdal Debian package has used
`/usr/share/gdal/<GDAL_VERSION_MARJOR>.<GDAL_VERSION_MINOR>` for
`GDAL_DATA` for a very long time.
# ls -l $(gdal-config --datadir)/gcs.csv
-rw-r--r-- 1 root root 54388 May 4 16:33 /usr/share/gdal/2.3/gcs.csv
`CPLFinderInit()` is patched to use this path instead of
`/usr/share/gdal`.
I suspect this code path is not used in 2.3 any more.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4078#comment:2>
