[postgis-tickets] r16560 - Add enhancement line to reference
Paul Ramsey
pramsey at cleverelephant.ca
Mon May 7 11:19:21 PDT 2018
Author: pramsey
Date: 2018-05-07 11:19:21 -0700 (Mon, 07 May 2018)
New Revision: 16560
trunk/doc/reference_output.xml
Modified: trunk/doc/reference_output.xml
--- trunk/doc/reference_output.xml 2018-05-07 18:05:37 UTC (rev 16559)
+++ trunk/doc/reference_output.xml 2018-05-07 18:19:21 UTC (rev 16560)
@@ -1480,6 +1480,7 @@
<para><varname>extent</varname> is the tile extent in screen space as defined by the specification. If NULL it will default to 4096.</para>
<para><varname>geom_name</varname> is the name of the geometry column in the row data. If NULL it will default to the first found geometry column.</para>
+ <para>Enhanced: 2.5.0 - added support parallel query.</para>
<para>Availability: 2.4.0</para>
</refsection>
