[postgis-tickets] [PostGIS] #4078: test_gdal_configured fails with GDAL 2.3.0-rc1
trac at osgeo.org
Mon May 7 12:05:45 PDT 2018
Reporter: Bas Couwenberg | Owner: pramsey
Type: defect | Status: new
Priority: high | Milestone: PostGIS 2.4.5
Component: postgis | Version: 2.4.x
Resolution: | Keywords:
Comment (by Bas Couwenberg):
Running `make check` via `strace` in `raster/test/cunit` works on my site
too, but the running the tests as part of the Debian package build (via
`pg_virtualenv`) still fails.
Running that `make check` invocation via `strace` shows that `gcs.csv` is
loaded correctly, but other tests fail.
This is starting to look like a heisenbug.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4078#comment:7>
