[postgis-tickets] [PostGIS] #4031: ST_CurveToLine with small tolerance sometimes causes invalid memory alloc request size
trac at osgeo.org
Tue May 15 23:11:22 PDT 2018
request size
Reporter: kkgeodk | Owner: strk
Type: defect | Status: assigned
Priority: medium | Milestone: PostGIS 2.5.0
Component: postgis | Version: 2.2.x
Resolution: | Keywords: ST_CurveToLine
Comment (by kkgeodk):
''@kkgeodk can you confirm r16553 fixes the problem for you ?''
Thank you, I was not able to reproduce the ERROR invalid memory alloc
request size with r16553.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4031#comment:13>
