[postgis-tickets] r16576 - Backport PG 11 compatibility
Raul
raul at rmr.ninja
Fri May 18 02:10:04 PDT 2018
Author: algunenano
Date: 2018-05-18 02:10:03 -0700 (Fri, 18 May 2018)
New Revision: 16576
branches/2.4/.gitignore
branches/2.4/extensions/address_standardizer/std_pg_hash.c
branches/2.4/libpgcommon/lwgeom_transform.c
branches/2.4/postgis/Makefile.in
branches/2.4/postgis/lwgeom_geos_prepared.c
branches/2.4/raster/test/regress/check_gdal.sql
branches/2.4/raster/test/regress/check_gdal_expected
Closes #4090
Closes https://github.com/postgis/postgis/pull/242
Modified: branches/2.4/.gitignore
--- branches/2.4/.gitignore 2018-05-16 21:39:45 UTC (rev 16575)
+++ branches/2.4/.gitignore 2018-05-18 09:10:03 UTC (rev 16576)
@@ -167,3 +167,7 @@
*.pdf
.idea/*
.syntastic_c_config
+# LLVM JIT
+*.bc
+*.ll
Modified: branches/2.4/extensions/address_standardizer/std_pg_hash.c
--- branches/2.4/extensions/address_standardizer/std_pg_hash.c 2018-05-16 21:39:45 UTC (rev 16575)
+++ branches/2.4/extensions/address_standardizer/std_pg_hash.c 2018-05-18 09:10:03 UTC (rev 16576)
@@ -91,22 +91,7 @@
static StdHashEntry *GetStdHashEntry(MemoryContext mcxt);
static void DeleteStdHashEntry(MemoryContext mcxt);
-/* Memory context cache function prototypes */
-static void StdCacheInit(MemoryContext context);
-static void StdCacheReset(MemoryContext context);
-static void StdCacheDelete(MemoryContext context);
-static bool StdCacheIsEmpty(MemoryContext context);
-#if POSTGIS_PGSQL_VERSION >= 96
-static void StdCacheStats(MemoryContext context, int level, bool print, MemoryContextCounters *totals);
-#else
-static void StdCacheStats(MemoryContext context, int level);
-#endif
-#ifdef MEMORY_CONTEXT_CHECKING
-static void StdCacheCheck(MemoryContext context);
-#endif
static bool IsInStdPortalCache(StdPortalCache *STDCache, char *lextab, char *gaztab, char *rultab);
static STANDARDIZER *GetStdFromPortalCache(StdPortalCache *STDCache, char *lextab, char *gaztab, char *rultab);
static void AddToStdPortalCache(StdPortalCache *STDCache, char *lextab, char *gaztab, char *rultab);
@@ -124,41 +109,19 @@
static int load_rules(RULES *rules, char *tabname);
-/* Memory context definition must match the current version of PostgreSQL */
-static MemoryContextMethods StdCacheContextMethods =
- NULL,
- NULL,
- NULL,
- StdCacheInit,
- StdCacheReset,
- StdCacheDelete,
- NULL,
- StdCacheIsEmpty,
- StdCacheStats
- , StdCacheCheck
-#endif
-static void
-StdCacheInit(MemoryContext context)
- /* NOP - initialized when first used. */
static void
-StdCacheReset(MemoryContext context)
- // NOP - Seems to be a required function
+#if POSTGIS_PGSQL_VERSION < 95
-static void
+#else
+StdCacheDelete(void *ptr)
+ MemoryContext context = (MemoryContext)ptr;
+#endif
StdHashEntry *she;
DBG("Enter: StdCacheDelete");
@@ -177,7 +140,21 @@
DeleteStdHashEntry(context);
+static void
+StdCacheInit(MemoryContext context)
+ /* NOP - initialized when first used. */
+static void
+StdCacheReset(MemoryContext context)
+ // NOP - Seems to be a required function
static bool
@@ -185,24 +162,13 @@
return FALSE;
static void
-StdCacheStats(MemoryContext context, int level, bool print, MemoryContextCounters *totals)
- // another required function
- fprintf(stderr, "%s: STANDARDIZER context\n", context->name);
-#else
-static void
-#endif
static void
@@ -211,7 +177,26 @@
#endif
+/* Memory context definition must match the current version of PostgreSQL */
+static MemoryContextMethods StdCacheContextMethods =
+ NULL,
+ NULL,
+ NULL,
+ StdCacheInit,
+ StdCacheReset,
+ StdCacheDelete,
+ NULL,
+ StdCacheIsEmpty,
+ StdCacheStats
+#ifdef MEMORY_CONTEXT_CHECKING
+ , StdCacheCheck
+#endif
+#endif /* POSTGIS_PGSQL_VERSION < 95 */
uint32
mcxt_ptr_hash_std(const void *key, Size keysize)
@@ -397,11 +382,28 @@
DBG("Adding item to STD cache ('%s', '%s', '%s') index %d", lextab, gaztab, rultab, STDCache->NextSlot);
STDMemoryContext = MemoryContextCreate(T_AllocSetContext, 8192,
&StdCacheContextMethods,
STDCache->StdCacheContext,
"PAGC STD Memory Context");
+#else
+ STDMemoryContext = AllocSetContextCreate(STDCache->StdCacheContext,
+ "PAGC STD Memory Context",
+ ALLOCSET_SMALL_SIZES);
+ /* PgSQL comments suggest allocating callback in the context */
+ /* being managed, so that the callback object gets cleaned along with */
+ /* the context */
+ MemoryContextCallback *callback = MemoryContextAlloc(STDMemoryContext, sizeof(MemoryContextCallback));
+ callback->arg = (void*)(STDMemoryContext);
+ callback->func = StdCacheDelete;
+ MemoryContextRegisterResetCallback(STDMemoryContext, callback);
+#endif
/* Create the backend hash if it doesn't already exist */
DBG("Check if StdHash exists (%p)", StdHash);
if (!StdHash)
Modified: branches/2.4/libpgcommon/lwgeom_transform.c
--- branches/2.4/libpgcommon/lwgeom_transform.c 2018-05-16 21:39:45 UTC (rev 16575)
+++ branches/2.4/libpgcommon/lwgeom_transform.c 2018-05-18 09:10:03 UTC (rev 16576)
@@ -98,7 +98,7 @@
static void
-#if POSTGIS_PGSQL_VERSION < 110
+#if POSTGIS_PGSQL_VERSION < 96
PROJ4SRSCacheDelete(MemoryContext context)
#else
@@ -112,7 +112,7 @@
projection = GetPJHashEntry(context);
if (!projection)
- elog(ERROR, "%s: Trying to delete non-existant projection object with MemoryContext key (%p)", __func__, (void *)context);
+ elog(ERROR, "PROJ4SRSCacheDelete: Trying to delete non-existant projection object with MemoryContext key (%p)", (void *)context);
POSTGIS_DEBUGF(3, "deleting projection object (%p) with MemoryContext key (%p)", projection, context);
/* Free it */
@@ -122,7 +122,7 @@
DeletePJHashEntry(context);
static void
PROJ4SRSCacheInit(MemoryContext context)
@@ -153,11 +153,7 @@
static void
-PROJ4SRSCacheStats(MemoryContext context, int level, bool print, MemoryContextCounters *totals)
-#else
PROJ4SRSCacheStats(MemoryContext context, int level)
-#endif
* Simple stats display function - we must supply a function since this call is mandatory according to tgl
@@ -195,9 +191,8 @@
#endif
-#endif /* POSTGIS_PGSQL_VERSION < 110 */
+#endif /* POSTGIS_PGSQL_VERSION < 96 */
* PROJ4 projPJ Hash Table functions
@@ -564,7 +559,7 @@
POSTGIS_DEBUGF(3, "adding SRID %d with proj4text \"%s\" to query cache at index %d", srid, proj_str, PROJ4Cache->PROJ4SRSCacheCount);
PJMemoryContext = MemoryContextCreate(T_AllocSetContext, 8192,
&PROJ4SRSCacheContextMethods,
PROJ4Cache->PROJ4SRSCacheContext,
@@ -583,7 +578,7 @@
MemoryContextRegisterResetCallback(PJMemoryContext, callback);
#endif
- /* Create the backend hash if it doesn't already exist */
+ /* Create the backend hash if it doesn't already exist */
if (!PJHash)
PJHash = CreatePJHash();
@@ -683,52 +678,7 @@
return (Proj4Cache)GetPROJ4SRSCache(fcinfo);
-#if 0
-static PROJ4PortalCache *GetPROJ4SRSCache(FunctionCallInfo fcinfo)
- PROJ4PortalCache *PROJ4Cache = (GetGeomCache(fcinfo))->proj;
- * If we have not already created PROJ4 cache for this portal
- * then create it
- if (fcinfo->flinfo->fn_extra == NULL)
- MemoryContext old_context;
- old_context = MemoryContextSwitchTo(fcinfo->flinfo->fn_mcxt);
- PROJ4Cache = palloc(sizeof(PROJ4PortalCache));
- MemoryContextSwitchTo(old_context);
- if (PROJ4Cache)
- int i;
- POSTGIS_DEBUGF(3, "Allocating PROJ4Cache for portal with transform() MemoryContext %p", fcinfo->flinfo->fn_mcxt);
- /* Put in any required defaults */
- for (i = 0; i < PROJ4_CACHE_ITEMS; i++)
- PROJ4Cache->PROJ4SRSCache[i].srid = SRID_UNKNOWN;
- PROJ4Cache->PROJ4SRSCache[i].projection = NULL;
- PROJ4Cache->PROJ4SRSCache[i].projection_mcxt = NULL;
- PROJ4Cache->PROJ4SRSCacheCount = 0;
- PROJ4Cache->PROJ4SRSCacheContext = fcinfo->flinfo->fn_mcxt;
- /* Store the pointer in fcinfo->flinfo->fn_extra */
- fcinfo->flinfo->fn_extra = PROJ4Cache;
- else
- /* Use the existing cache */
- PROJ4Cache = fcinfo->flinfo->fn_extra;
- return PROJ4Cache ;
-#endif
* Given a function call context, figure out what namespace the
* function is being called from, and copy that into a global
Modified: branches/2.4/postgis/Makefile.in
--- branches/2.4/postgis/Makefile.in 2018-05-16 21:39:45 UTC (rev 16575)
+++ branches/2.4/postgis/Makefile.in 2018-05-18 09:10:03 UTC (rev 16576)
@@ -118,8 +118,7 @@
# to an existing liblwgeom.so in the PostgreSQL $libdir supplied by an
# older version of PostGIS, rather than with the static liblwgeom.a
# supplied with newer versions of PostGIS
-override CFLAGS := -I../liblwgeom @CFLAGS@
-PG_CPPFLAGS += -I../libpgcommon @CPPFLAGS@ -fPIC
+PG_CPPFLAGS += -I../liblwgeom @CFLAGS@ -I../libpgcommon @CPPFLAGS@ -fPIC
SHLIB_LINK_F = ../libpgcommon/libpgcommon.a ../liblwgeom/.libs/liblwgeom.a @SHLIB_LINK@
# Add SFCGAL Flags if defined
Modified: branches/2.4/postgis/lwgeom_geos_prepared.c
--- branches/2.4/postgis/lwgeom_geos_prepared.c 2018-05-16 21:39:45 UTC (rev 16575)
+++ branches/2.4/postgis/lwgeom_geos_prepared.c 2018-05-18 09:10:03 UTC (rev 16576)
@@ -96,7 +96,7 @@
static void
PreparedCacheDelete(MemoryContext context)
#else
@@ -111,7 +111,7 @@
pghe = GetPrepGeomHashEntry(context);
if (!pghe)
- elog(ERROR, "%s: Trying to delete non-existant hash entry object with MemoryContext key (%p)", __func__, (void *)context);
+ elog(ERROR, "PreparedCacheDelete: Trying to delete non-existant hash entry object with MemoryContext key (%p)", (void *)context);
POSTGIS_DEBUGF(3, "deleting geom object (%p) and prepared geom object (%p) with MemoryContext key (%p)", pghe->geom, pghe->prepared_geom, context);
@@ -125,8 +125,7 @@
DeletePrepGeomHashEntry(context);
static void
PreparedCacheInit(MemoryContext context)
@@ -167,7 +166,6 @@
* (see postgis-devel archives July 2007)
fprintf(stderr, "%s: Prepared context\n", context->name);
@@ -199,7 +197,7 @@
#endif
/* TODO: put this in common are for both transform and prepared
@@ -319,7 +317,7 @@
if ( ! prepcache->context_callback )
PrepGeomHashEntry pghe;
prepcache->context_callback = MemoryContextCreate(T_AllocSetContext, 8192,
&PreparedCacheContextMethods,
prepcache->context_statement,
@@ -338,6 +336,8 @@
callback->func = PreparedCacheDelete;
MemoryContextRegisterResetCallback(prepcache->context_callback, callback);
#endif
pghe.context = prepcache->context_callback;
pghe.geom = 0;
pghe.prepared_geom = 0;
Modified: branches/2.4/raster/test/regress/check_gdal.sql
--- branches/2.4/raster/test/regress/check_gdal.sql 2018-05-16 21:39:45 UTC (rev 16575)
+++ branches/2.4/raster/test/regress/check_gdal.sql 2018-05-18 09:10:03 UTC (rev 16576)
@@ -5,13 +5,8 @@
THEN false
ELSE NULL
END;
-SET postgis.gdal_datapath = '';
-SELECT
- CASE
- WHEN strpos(postgis_gdal_version(), 'GDAL_DATA') <> 0
- THEN NULL
- ELSE TRUE
- END;
+SET postgis.gdal_datapath = 'invalid_path';
+SHOW postgis.gdal_datapath;
SET postgis.gdal_datapath = default;
SELECT
CASE
Modified: branches/2.4/raster/test/regress/check_gdal_expected
--- branches/2.4/raster/test/regress/check_gdal_expected 2018-05-16 21:39:45 UTC (rev 16575)
+++ branches/2.4/raster/test/regress/check_gdal_expected 2018-05-18 09:10:03 UTC (rev 16576)
@@ -1,3 +1,4 @@
+invalid_path
t
DISABLE_ALL
ENABLE_ALL
