[postgis-tickets] [PostGIS] #4090: Backport PG11 support to Postgis 2.4
PostGIS trac at osgeo.org
Mon May 21 03:41:33 PDT 2018
  Reporter:  Algunenano   |      Owner:  Algunenano
      Type:  enhancement  |     Status:  closed
  Priority:  medium       |  Milestone:  PostGIS 2.4.5
 Component:  postgis      |    Version:  2.4.x
Resolution:  fixed        |   Keywords:
Comment (by Raul Marin):
 In [changeset:"16578" 16578]:
 #!CommitTicketReference repository="" revision="16578"
 Fix PG 9.5 build in 2.4
 References #4090
 Applies the same fix as #3950
 Closes https://github.com/postgis/postgis/pull/243
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4090#comment:2>
