[postgis-tickets] [PostGIS] #4096: ST_Intersects does not return error when comparing different SRIDs
PostGIS trac at osgeo.org
Thu May 24 07:37:54 PDT 2018
  Reporter:  katbot   |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  low      |  Milestone:  PostGIS 2.4.5
 Component:  postgis  |    Version:  2.4.x
Resolution:           |   Keywords:
Comment (by komzpa):
 This happens due to following optimization:
 ST_Intersects is in fact replaced to calls to && and _ST_Intersects. && is
 fast indexed operator that works on boxes and does not check srid, as
 boxes don't have one. _ST_Intersects performs the check, but is never
 called if boxes don't intersect.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4096#comment:1>
