[postgis-tickets] [PostGIS] #4096: ST_Intersects does not return error when comparing different SRIDs
PostGIS trac at osgeo.org
Mon May 28 06:10:40 PDT 2018
  Reporter:  katbot   |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  low      |  Milestone:  PostGIS 2.4.5
 Component:  postgis  |    Version:  2.4.x
Resolution:           |   Keywords:
Comment (by katbot):
 OK, understood about the reasons for optimization. Perhaps this is a
 documentation issue, then? Maybe this is common sense to some, but was not
 obvious to me that matching SRIDs was necessary for the ST_Intersects
 function (or ST_Contains, ST_Within, or others), and was not documented.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4096#comment:2>
