[postgis-tickets] r16591 - put back pgis_abs_in and pgis_abs_out as stubs to maintain lib compatibility with PostGIS 2.4 and below
Regina Obe lr at pcorp.us
Mon May 28 03:49:35 PDT 2018
Author: robe
Date: 2018-05-28 15:49:35 -0700 (Mon, 28 May 2018)
New Revision: 16591
   trunk/postgis/lwgeom_accum.c
References #4097
Modified: trunk/postgis/lwgeom_accum.c
--- trunk/postgis/lwgeom_accum.c	2018-05-23 09:40:23 UTC (rev 16590)
+++ trunk/postgis/lwgeom_accum.c	2018-05-28 22:49:35 UTC (rev 16591)
@@ -50,6 +50,32 @@
 Datum pgis_geometry_clusterintersecting_finalfn(PG_FUNCTION_ARGS);
 Datum pgis_geometry_clusterwithin_finalfn(PG_FUNCTION_ARGS);
+/** Putting pgis_abs back for ABI compatibility with 2.4 and below
+ * TODO: Drop when 3.0 rolls around **/
+Datum pgis_abs_in(PG_FUNCTION_ARGS);
+Datum pgis_abs_out(PG_FUNCTION_ARGS);
+** Putting back pgis_* for ABI compatibility to smooth pg_upgrade
+** TODO: Drop when 3.0 rolls around
+PG_FUNCTION_INFO_V1(pgis_abs_in);
+Datum
+pgis_abs_in(PG_FUNCTION_ARGS)
+	ereport(ERROR,(errcode(ERRCODE_FEATURE_NOT_SUPPORTED),
+	               errmsg("function %s not implemented", __func__)));
+	PG_RETURN_POINTER(NULL);
+PG_FUNCTION_INFO_V1(pgis_abs_out);
+Datum
+pgis_abs_out(PG_FUNCTION_ARGS)
 /* External prototypes */
 Datum pgis_union_geometry_array(PG_FUNCTION_ARGS);
 Datum LWGEOM_collect_garray(PG_FUNCTION_ARGS);
