[postgis-tickets] [PostGIS] #4097: binary upgrade fail going from 10 (2.4) to 11 (head) (2.5)
PostGIS trac at osgeo.org
Mon May 28 15:53:19 PDT 2018
  Reporter:  robe                   |      Owner:  robe
      Type:  defect                 |     Status:  assigned
  Priority:  blocker                |  Milestone:  PostGIS 2.5.0
 Component:  build/upgrade/install  |    Version:  trunk
Resolution:                         |   Keywords:
Comment (by robe):
 Okay I put these back and that got rid of the pgis_abs error, but I'm
 still getting troubling crashes in raster and in different location from
 what I got earlier.
 pg_restore: creating COMMENT "public.FUNCTION
 "addgeometrycolumn"("catalog_name" character varying, "schema_name"
 character varying, "table_name" character varying, "column_name" character
 varying, "new_srid_in" integer, "new_type" character varying, "new_dim"
 integer, "use_typmod" boolean)"
 pg_restore: creating FUNCTION "public.addoverviewconstraints("name",
 "name", "name", "name", integer)"
 "addoverviewconstraints"("ovtable" "name", "ovcolumn" "name", "reftable"
 "name", "refcolumn" "name", "ovfactor" integer)"
 "name", "name", "name", "name", "name", integer)"
 "addoverviewconstraints"("ovschema" "name", "ovtable" "name", "ovcolumn"
 "name", "refschema" "name", "reftable" "name", "refcolumn" "name",
 pg_restore: creating FUNCTION "public.addrasterconstraints("name", "name",
 "text"[])"
 "addrasterconstraints"("rasttable" "name", "rastcolumn" "name", VARIADIC
 "constraints" "text"[])"
 "name", "text"[])"
 "addrasterconstraints"("rastschema" "name", "rasttable" "name",
 "rastcolumn" "name", VARIADIC "constraints" "text"[])"
 boolean, boolean, boolean, boolean, boolean, boolean, boolean, boolean,
 boolean, boolean, boolean, boolean)"
 pg_restore: [archiver (db)] Error while PROCESSING TOC:
 pg_restore: [archiver (db)] Error from TOC entry 1172; 1255 16806 FUNCTION
 addrasterconstraints("name", "name", boolean, boolean, boolean, boolean,
 boolean, boolean, boolean, boolean, boolean, boolean, boolean, boolean)
 postgres
 pg_restore: [archiver (db)] could not execute query: FATAL:  terminating
 connection due to administrator command
 server closed the connection unexpectedly
         This probably means the server terminated abnormally
         before or while processing the request.
     Command was: ALTER FUNCTION
 "public"."addrasterconstraints"("rasttable" "name", "rastcolumn" "name",
 "srid" boolean, "scale_x" boolean, "scale_y" boolean, "blocksize_x"
 boolean, "blocksize_y" boolean, "same_alignment" boolean,
 "regular_blocking" boolean, "num_bands" boolean, "pixel_types" boolean,
 "nodata_values" boolean, "out_db" boolean, "extent" boolean) OWNER TO
 postgres;
 command:
 "C:\ming64gcc48\projects\postgresql\rel\pg11w64gcc48\bin/pg_restore"
 --port 5448 --username postgres --clean --create --exit-on-error --verbose
 --dbname template1 "pg_upgrade_dump_12938.custom" >>
 "pg_upgrade_dump_12938.log" 2>&1
 So I'll leave this open until I figure out what's up here.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4097#comment:4>
