[postgis-tickets] [PostGIS] #4097: binary upgrade fail going from 10 (2.4) to 11 (head) (2.5)
PostGIS trac at osgeo.org
Mon May 28 15:49:36 PDT 2018
  Reporter:  robe                   |      Owner:  robe
      Type:  defect                 |     Status:  assigned
  Priority:  blocker                |  Milestone:  PostGIS 2.5.0
 Component:  build/upgrade/install  |    Version:  trunk
Resolution:                         |   Keywords:
Comment (by robe):
 In [changeset:"16591" 16591]:
 #!CommitTicketReference repository="" revision="16591"
 put back pgis_abs_in and pgis_abs_out as stubs to maintain lib
 compatibility with PostGIS 2.4 and below
 References #4097
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4097#comment:3>
