[postgis-tickets] r16986 - Add name to NEWS
Paul Ramsey pramsey at cleverelephant.ca
Tue Nov 6 02:27:25 PST 2018
Author: pramsey
Date: 2018-11-06 14:27:25 -0800 (Tue, 06 Nov 2018)
New Revision: 16986
   branches/2.4/NEWS
Add name to NEWS
Modified: branches/2.4/NEWS
--- branches/2.4/NEWS	2018-11-06 22:26:49 UTC (rev 16985)
+++ branches/2.4/NEWS	2018-11-06 22:27:25 UTC (rev 16986)
@@ -12,9 +12,10 @@
   - #4206, Fix support for PostgreSQL 12 dev branch (Laurenz Albe)
   - #3457, Fix raster envelope shortcut in ST_Clip (Sai-bot)
   - #4215, Use floating point compare in ST_DumpAsPolygons (Darafei Praliaskouski)
-  - #4059, #4177, Remove use of variable length arrays
-  - #4216, Return to slicing for bbox access in gserialized
-  - #4136, Proper repeated point removal on small polygons
+  - #4059, #4177, Remove use of variable length arrays (Paul Ramsey)
+  - #4216, Return to slicing for bbox access in gserialized (Paul Ramsey)
+  - #4136, Proper repeated point removal on small polygons (Paul Ramsey)
+  - #4223, ST_DistanceTree error for near parallel boxes (Paul Ramsey)
 PostGIS 2.4.5
