[postgis-tickets] [PostGIS] #4241: PostgreSQL 12 build against trunk is broken
PostGIS trac at osgeo.org
Sun Nov 18 00:57:36 PST 2018
 Reporter:  robe     |      Owner:  robe
     Type:  defect   |     Status:  assigned
 Priority:  blocker  |  Milestone:  PostGIS 3.0.0
Component:  raster   |    Version:  2.4.x
 Keywords:           |
 Failing on raster constraint check
 psql:/var/lib/jenkins/workspace/postgis/branches/3.0/regress/00-regress-
 install/share/contrib/postgis/postgis.sql:6921: ERROR:  column s.consrc
 does not exist
 LINE 3: SELECT replace(replace(split_part(s.consrc, ' = ', 2), ')', ...
 HINT:  Perhaps you meant to reference the column "s.conkey" or the column
 "s.conbin".
 make[2]: *** [Makefile:259: check] Error 1
 make[2]: Leaving directory
 '/var/lib/jenkins/workspace/postgis/branches/3.0/regress/core'
 make[1]: *** [Makefile:28: check] Error 2
 make[1]: Leaving directory
 '/var/lib/jenkins/workspace/postgis/branches/3.0/regress'
 make: *** [GNUmakefile:20: check] Error 1
 Build step 'Execute shell' marked build as failure
 An attempt to send an e-mail to empty list of recipients, ignored.
 I'm guessing they dropped some system columns or renamed them
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4241>
