r17035 - Avoid undefined behaviour in next_float functions (Raúl Marín)
Raul
raul at rmr.ninja
Wed Nov 21 03:43:09 PST 2018
Author: algunenano
Date: 2018-11-21 03:43:09 -0800 (Wed, 21 Nov 2018)
New Revision: 17035
branches/2.3/NEWS
branches/2.3/liblwgeom/cunit/cu_libgeom.c
branches/2.3/liblwgeom/lwgeom_api.c
References #4247
Modified: branches/2.3/NEWS
--- branches/2.3/NEWS 2018-11-19 16:21:03 UTC (rev 17034)
+++ branches/2.3/NEWS 2018-11-21 11:43:09 UTC (rev 17035)
@@ -16,6 +16,7 @@
- #3457, Fix raster envelope shortcut in ST_Clip (Sai-bot)
- #4223, Fix parallel/near rectangle case in geography (Paul Ramsey)
- #4326, Allocate enough memory in gidx_to_string (Raúl Marín)
+ - #4247, Avoid undefined behaviour in next_float functions (Raúl Marín)
PostGIS 2.3.7
2018/04/06
Modified: branches/2.3/liblwgeom/cunit/cu_libgeom.c
--- branches/2.3/liblwgeom/cunit/cu_libgeom.c 2018-11-19 16:21:03 UTC (rev 17034)
+++ branches/2.3/liblwgeom/cunit/cu_libgeom.c 2018-11-21 11:43:09 UTC (rev 17035)
@@ -688,6 +688,26 @@
f = next_float_up(d);
d = next_float_up(f);
CU_ASSERT_DOUBLE_EQUAL(f,d, 0.0000001);
+ d = DBL_MAX;
+ f = next_float_up(d);
+ d = next_float_up(f);
+ CU_ASSERT_DOUBLE_EQUAL(f, d, 0.0000001);
+ d = DBL_MAX;
+ f = next_float_down(d);
+ d = next_float_down(f);
+ d = -DBL_MAX;
+ d = -DBL_MAX;
Modified: branches/2.3/liblwgeom/lwgeom_api.c
--- branches/2.3/liblwgeom/lwgeom_api.c 2018-11-19 16:21:03 UTC (rev 17034)
+++ branches/2.3/liblwgeom/lwgeom_api.c 2018-11-21 11:43:09 UTC (rev 17035)
@@ -155,7 +155,12 @@
float next_float_down(double d)
- float result = d;
+ float result;
+ if (d > (double)FLT_MAX)
+ return FLT_MAX;
+ if (d <= (double)-FLT_MAX)
+ return -FLT_MAX;
+ result = d;
if ( ((double) result) <=d)
return result;
@@ -171,7 +176,12 @@
float
next_float_up(double d)
- float result = d;
+ float result;
+ if (d >= (double)FLT_MAX)
+ return FLT_MAX;
+ if (d < (double)-FLT_MAX)
+ return -FLT_MAX;
+ result = d;
if ( ((double) result) >=d)
return result;
