r17036 - Avoid undefined behaviour in next_float functions (Raúl Marín)
Raul
raul at rmr.ninja
Wed Nov 21 03:43:57 PST 2018
Author: algunenano
Date: 2018-11-21 03:43:57 -0800 (Wed, 21 Nov 2018)
New Revision: 17036
branches/2.4/NEWS
branches/2.4/liblwgeom/cunit/cu_libgeom.c
branches/2.4/liblwgeom/lwgeom_api.c
References #4247
Modified: branches/2.4/NEWS
--- branches/2.4/NEWS 2018-11-21 11:43:09 UTC (rev 17035)
+++ branches/2.4/NEWS 2018-11-21 11:43:57 UTC (rev 17036)
@@ -17,7 +17,8 @@
- #4136, Proper repeated point removal on small polygons (Paul Ramsey)
- #4223, ST_DistanceTree error for near parallel boxes (Paul Ramsey)
- #4326, Allocate enough memory in gidx_to_string (Raúl Marín)
- - #4190, Avoid undefined behaviour in gserialized_estimate
+ - #4190, Avoid undefined behaviour in gserialized_estimate (Raúl Marín)
+ - #4247, Avoid undefined behaviour in next_float functions (Raúl Marín)
PostGIS 2.4.5
Modified: branches/2.4/liblwgeom/cunit/cu_libgeom.c
--- branches/2.4/liblwgeom/cunit/cu_libgeom.c 2018-11-21 11:43:09 UTC (rev 17035)
+++ branches/2.4/liblwgeom/cunit/cu_libgeom.c 2018-11-21 11:43:57 UTC (rev 17036)
@@ -688,6 +688,26 @@
f = next_float_up(d);
d = next_float_up(f);
CU_ASSERT_DOUBLE_EQUAL(f,d, 0.0000001);
+ d = DBL_MAX;
+ f = next_float_up(d);
+ d = next_float_up(f);
+ CU_ASSERT_DOUBLE_EQUAL(f, d, 0.0000001);
+ d = DBL_MAX;
+ f = next_float_down(d);
+ d = next_float_down(f);
+ d = -DBL_MAX;
+ d = -DBL_MAX;
Modified: branches/2.4/liblwgeom/lwgeom_api.c
--- branches/2.4/liblwgeom/lwgeom_api.c 2018-11-21 11:43:09 UTC (rev 17035)
+++ branches/2.4/liblwgeom/lwgeom_api.c 2018-11-21 11:43:57 UTC (rev 17036)
@@ -50,7 +50,12 @@
inline float
next_float_down(double d)
- float result = d;
+ float result;
+ if (d > (double)FLT_MAX)
+ return FLT_MAX;
+ if (d <= (double)-FLT_MAX)
+ return -FLT_MAX;
+ result = d;
if ( ((double)result) <=d )
return result;
@@ -66,7 +71,12 @@
inline float
next_float_up(double d)
- float result = d;
+ float result;
+ if (d >= (double)FLT_MAX)
+ return FLT_MAX;
+ if (d < (double)-FLT_MAX)
+ return -FLT_MAX;
+ result = d;
if ( ((double)result) >=d )
return result;
